Easy 2wd low?
Old Mar 30, 2010 | 09:07 AM
95RAM360's Avatar
95RAM360
change your plenum, then i bet it will pull it right out in 2wd
Old Mar 30, 2010 | 11:59 AM
Maxx_Magnum's Avatar
Maxx_Magnum
the easiest way is to remove the front driveshaft. The best way would be to install a Posilok.
Old Mar 30, 2010 | 12:04 PM
MrRuckuss's Avatar
MrRuckuss
^^^^^ wish i would have thought of that yesterday! i tend to forget about that as i have the v10 not the problem child v8's lol j/k
Old Mar 30, 2010 | 03:22 PM
duped's Avatar
duped
Thanks guys driveshaft it is. I'm apprehensive about using 4 lo because I often have to steer away from the ramp a bit and the front tires stay on dry ground. It's a 24 foot bayliner Ciera. weighs around 5000 lbs plus tandem trailer. A "good size boat" thanks again. Just wanted to be sure of things!
