Mopar performance valve covers...
Old Mar 8, 2010 | 05:33 PM
mr freeze's Avatar
mr freeze
Default Mopar performance valve covers...
Is it true that these things leak through the grommets and make a mess on the engine? If so should I get the baffles that they sell at APS? Gonna hopefully do the 1.7s rr next weekend so I need to order them soon if I need them.
Old Mar 8, 2010 | 06:28 PM
Twisted Metal's Avatar
Twisted Metal
I have heard yes and no on the leaking Freeze. I had a pair on my 99 5.9 that would weep alittle around the breather. But nothing that was major. I'd double check on the baffles with the 1.7's, IIRC Harland Sharps' stated the baffles would have to be removed or modified. I can't recal if they meant OEM cover or MP ones though.
Old Mar 9, 2010 | 12:42 AM
BlueBeast2's Avatar
BlueBeast2
If you get the right ones I believe you'll be fine. I also think the aps baffles are made to work with the rr's. Silver would know better on this subject
Old Mar 9, 2010 | 01:07 AM
dodgeram07's Avatar
dodgeram07
You thinking you have diff covers when you rr's? Because the southrr's the ones alot of people get work under stock covers
sorry if I read into that
Old Mar 9, 2010 | 09:52 AM
RM_Indy's Avatar
RM_Indy
Mopar alum valve covers do weep a bit at the grommets as mentioned.
They come with baffles included btw
I was running Crower 1.7rr with the baffles in though they were a small ss rocker.
I only removed my baffles cause of the rocker girdles I have ontop of my HS1.6rr.
From my understanding the HS 1.7rr wont fit stock valve covers, should be fine under the taller MP alum covers
Old Mar 9, 2010 | 10:22 AM
ramit700's Avatar
ramit700
I've been running them for about 6 years. The baffles are included. I've had no issues with weeping around the grommets. Every once and a while I'll get a little weeping around the fill cap and I'll have to bend the tabs on the cap to create a better seal.
Old Mar 9, 2010 | 10:24 AM
Gerehead8's Avatar
Gerehead8
I have HS 1.7 RR's and they fit fine under my stock valve covers. I thought one of the HS's main selling points was that they fit under the stock covers.
Old Mar 9, 2010 | 12:10 PM
BlueBeast2's Avatar
BlueBeast2
They should fit under the stockers. If you really look the MP covers are stock height. I found this out when I thought I needed taller covers.
Old Mar 9, 2010 | 02:07 PM
aim4squirrels's Avatar
aim4squirrels
Stud mount converted rockers will not fit under the stock covers. The pedestal mount HS rockers will fit under the stock covers in the 1.6 or 1.7 variety.
Most any rocker can be made to fit under the stock valve cover, but you need to smash the baffle down with a length of 2x4 and a sledge.
Old Mar 9, 2010 | 03:40 PM
mr freeze's Avatar
mr freeze
I have the mopar covers and the rocker rollers already.I havent installed either one yet but I dont want oil seeping on the covers because it defeat the purpose of looking good.I think I'm just gonna buy the aps baffles and have it over with.Just hope the weather continues like it has for the past few days.
