stuck at 2000 rpms help
Old Mar 30, 2010 | 06:17 PM
diablo29's Avatar
diablo29
Default stuck at 2000 rpms help
I was driving and my cummins acellerated on its own up to 2000 rpms and will not come down under it. you can rev it up high put will not come back down. I have a couple of codes po230 seems to stand out the most the other is a map sensor code any ideaS?
Old Mar 30, 2010 | 06:29 PM
Maxx_Magnum's Avatar
Maxx_Magnum
have you been parking too close to a Toyota??
j/k man, I can't really help ya out but someone here will.... welcome to df!
Old Mar 30, 2010 | 06:33 PM
dodgeboy1979's Avatar
dodgeboy1979
the code you show is for a fuel pump relay, i'm assuming this is the pump in the tank and not the injection pump, get a haynes manual and see where this may be located and replace the relay. that's where I would start.
Old Mar 30, 2010 | 06:35 PM
diablo29's Avatar
diablo29
i wish it were that simple the code is supose to be for a bad lift pump but i got plently of fuel pressure it is driving me nutts
Old Mar 30, 2010 | 06:52 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF.
I'd also try posting this question in the diesel section of the forum, they may be able to help you as well. These questions are one of those rare occasions where I ignore the "no double posting" rule.
Old Mar 30, 2010 | 08:01 PM
j_mccans's Avatar
j_mccans
i know this sounds stupid but check the cruise control solinoid. i have had two dodge trucks one gas and one diesel both have done it to me the solinod would stick and the truck would just take off. i had to unhook the solinoid cable from where the throttle cable mounts if thats any help
Old Mar 30, 2010 | 09:49 PM
diablo29's Avatar
diablo29
ill try any thing thanks
Old Mar 31, 2010 | 04:26 PM
dodgeboy1979
what year of truck is it?
