3" spacers or 1 ton coils?
Old Mar 31, 2010 | 11:06 PM
BigRedRam95's Avatar
BigRedRam95
Originally Posted by xxxcowxboyxxx
my 99 i just got rid of i had put 1 ton coils in. i got them from an 05 cummins 3500. i gained 4 inches in the front and added 3" blocks in the rear and i was up and level on 35's, looked nice and rode great
you had 4 inches of lift and had stock control arms? do you thank I would be ok if I got 3500 springs and put a 2inch spacer on top without replacing the control arms?
Old Mar 31, 2010 | 11:15 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
i just measured my old ones for ya and they are 15 3/8 but they were the origionals from my 99 so they arent true anymore, most likely would be longer
Old Mar 31, 2010 | 11:17 PM
xxxcowxboyxxx
no way...... replace the control arms, drop pitman arm, drop swy bar bracket, longer brake lines, and everything else. doing what i did is about the max i would do withought getting into changing everything else including shocks. which i also changed when i did the coil swap
Old Mar 31, 2010 | 11:19 PM
j_mccans's Avatar
j_mccans
thanks i am going to yank one tomarrow there is alift on there now i have 35s on it but i think the coils are stock they have these wierd spacers in the coils that you put in between the coils and turn with a wrench.
Old Mar 31, 2010 | 11:22 PM
xxxcowxboyxxx
get them things out of there.....they are a waste. makes your ride stiff as hell too bc it doesnt allow coil to do what its made to do....compress
Old Mar 31, 2010 | 11:30 PM
BigRedRam95
Do you know where I can get a good deal on a set of control arms
Old Mar 31, 2010 | 11:33 PM
xxxcowxboyxxx
your best off going with an actual lift kit if your thinkin about piecin together a backyard 6" lift..... depends on what your price range is.
Old Mar 31, 2010 | 11:44 PM
BigRedRam95
I was going to put the rear leaf springs and the front springs off a one ton on my 1/2 ton then level it with the 2inch spacers.
Old Mar 31, 2010 | 11:47 PM
xxxcowxboyxxx
you cant use the rear springs fom a 1 ton on a 1/2 ton, they are wider and wont fit in the shakles
Old Mar 31, 2010 | 11:49 PM
xxxcowxboyxxx
thats too much lift on a 1/2 ton on stock components. all your angles will be wrong withought the other things i mentioned.
