Tranny fluid change
Old Apr 1, 2010 | 01:06 PM
yellowmopar3's Avatar
yellowmopar3
Default Tranny fluid change
All right, like alot of you guys I do not trust any joe shmo working on my truck. And it is time My tranny fluid is changed. I was just wondering if anyone had any tips or advice in this department. Best way to get all the fluid out, Do I need to change the filter. Stuff like that. Any input is greatly apriciated! Thank you!!!
Old Apr 1, 2010 | 01:12 PM
Maxx_Magnum's Avatar
Maxx_Magnum
you don't need to have alllll the fluid out for a normal fluid change, the TC holds a lot in it. And yes definitely change the filter when ya do it, and make sure you use only ATF+4! very important!
just carefully drop the pan, loosen all bolts then start removing them from one end, slowly lowering one end of the pan down to drain the fluid. PS: yer gonna get messy lol.... Some people like to go to a parts store and pick up a DIY drain plug, like 5 bucks and it'll make the next change so much nicer....
95RAM360 just changed his a couple days ago, check page 2 or 3 of this forum for his thread
Old Apr 1, 2010 | 01:19 PM
pcfixerpro's Avatar
pcfixerpro
There are plenty of diy's on trans filter change, which is why I never bothered writing a diy. I do have pictures from mine though if you'd like to glance through.
http://s422.photobucket.com/albums/p...lter%20Change/
Old Apr 1, 2010 | 01:35 PM
yellowmopar3
Thanks guys! So there is no way to get all of the fluid out 100%.
Old Apr 1, 2010 | 01:43 PM
Maxx_Magnum
well technically there is a way, it involves unhooking the cooler lines and letting the tranny pump it out while running. I don't llike the idea of that though, seems kinda like cutting an artery and bleeding out, when you just went in for a blood transfusion
A normal transmission fluid change just replaces the fluid in the pan, and the filter.... both ways have their pros and cons....
