Is your truck having shifting issues?
Old Apr 4, 2010 | 07:30 PM
PurplDodge's Avatar
PurplDodge
Originally Posted by MonteC
Yes i just finished one for a board member, worked beautifully. He drove it three hours back home. BUT always, always, always check your TV cable FIRST. This post was made with the assumption that everyones tv cable is adjusted properly and is in good working order.
Thanks for reminding me! I need to adjust mine!
Old Mar 27, 2014 | 07:47 PM
lsky6969's Avatar
lsky6969
Exclamation shifting issuses
ok i have read just about every thing on hear about the 46re transmission and shifting.....but my truck 99 with 318 4x4 w/46re trans shift fine until i hit a pot hole or a bump in the road then it shift to passing gear then back????? im confuse as to what is really wrong. please help!!!!
Old Mar 28, 2014 | 09:07 AM
xjarhead69's Avatar
xjarhead69
Sounds like wiring issue either inside the tranny or out.
I would check the wire for the OD solenoid.
Dave
Old Mar 28, 2014 | 09:44 AM
charlie1935's Avatar
charlie1935
Maybe you hit the bump so hard your moves on the accelerator pedal.
Old Mar 28, 2014 | 10:11 AM
lsky6969's Avatar
lsky6969
Xjarhead69 that's what I've been thinking..... Read somewhere that the 02sensors share ground with the transmission harness?
Charlie 1935 if you have ever drove on 285 in Atlanta it's the bumper than most dirt roads I've been on..
Old Mar 29, 2014 | 05:24 PM
lsky6969's Avatar
lsky6969
Default fixed!!!! i hope.
well i think i have fix the problem got to looking under truck again this time looking for wires loose something then i found it 3 wire that come off backside transmission that connects to 02 sensor the wires had been shaved the coating gone wire sightly broken so wire riding they touch ground out. rewire them with heat sink connectors then wrapped in black tape place them above heat shield.
Attached Thumbnails Is your truck having shifting issues?-img_20140328_162642_682.jpg   Is your truck having shifting issues?-img_20140328_163240_187.jpg
Old Mar 29, 2014 | 06:23 PM
charlie1935
Yes I have, but not in a couple of years. It was that way then too.
