Is your truck having shifting issues?
Old Apr 3, 2010 | 09:48 PM
MonteC's Avatar
MonteC
Default Is your truck having shifting issues?
Not shifting out of gear? Late shifts? Early shifts? This is what you need, i finally got my hands on one of these and i believe it is THE cure for the 46re governor pressure solenoid.
http://dnjcomponents.com/index.php
It utilizes a GM EPC solenoid (electronic pressure control), with a self cleaning valve inside, unlike the pressure solenoid found in the 46re. This set up gives you much more reliable governor pressure and is extremely stable at WOT.
This set up will not fix damaged transmissions, if you have a high mileage unit, a unit that is slipping, making noise or has nasty fluid with sediment in the pan i would not recommend this set up.
I would recommend this for low mileage units, recently rebuilt units or buy it and have it installed during a rebuild. I am in NO WAY affiliated with this product, just trying to educate you dodge guys and help you make that transmission work better and last longer.
Old Apr 3, 2010 | 09:53 PM
Mowhawk's Avatar
Mowhawk
Thank you thank you...thank you.
I will be getting this
Old Apr 3, 2010 | 10:05 PM
xjarhead69's Avatar
xjarhead69
Dodge "RE" Governor Solenoid to GM
Pressure Control Solenoid Conversion Kit
#REC. This kit was specifically designed to handle higher base pressure in high performance applications and to improve the reliability of the governor solenoid in normal use. In performance units the pressure can flood the Dodge solenoid and cause a no shift condition at full throttle. This is the fix. Fits all rear wheel drive RE model transmissions. Cost $149.00
Is this the same thing from http://www.transmissioncenter.net/dodge.htm?
Dave
Old Apr 3, 2010 | 11:25 PM
Trey318's Avatar
Trey318
Looks just like it.
Old Apr 3, 2010 | 11:34 PM
MonteC's Avatar
MonteC
Yep same thing.
Either one will work great! The key is the GM EPC solenoid.
Old Apr 3, 2010 | 11:40 PM
Ram_Me's Avatar
Ram_Me
I've heard about this.. I overheard my transmission guys talking over whether or not my truck would be a good candidate for this solenoid. When I bring it back this week, this is what they'll put in for sure.
Old Apr 3, 2010 | 11:45 PM
CPTAFW163's Avatar
CPTAFW163
My truck has 48K miles, and i have no slipping issues. Maybe i should get this since I will be doing a drain and fill...as soon as I get my Truck back from the dealership. 8 days and they still have not replaced the Transfer Case. I thought it was a bad seal, but ended up my TC was cracked.
Old Apr 4, 2010 | 12:11 AM
DukesOfHazzard's Avatar
DukesOfHazzard
I'm coming up on a fluid/filter change, is this a easy install? Seems like i get a really early shift when driving slow, just something ive' been noticing alot more. 100k + and no known problems, just a early upshift/downshift?? when driving below 15-20 mph. Monte have you used Sure Cure kits from sonnax with this?
Old Apr 4, 2010 | 12:14 AM
CPTAFW163's Avatar
CPTAFW163
The install is this...but with the better part:
https://dodgeforum.com/forum/2nd-gen...install-3.html
Old Apr 4, 2010 | 01:58 AM
MonteC's Avatar
MonteC
Yes i just finished one for a board member, worked beautifully. He drove it three hours back home. BUT always, always, always check your TV cable FIRST. This post was made with the assumption that everyones tv cable is adjusted properly and is in good working order.
