MonteC's Transmission Corner (For Info Only)
Old May 30, 2010 | 08:03 PM
  #321
xjarhead69's Avatar
xjarhead69
Originally Posted by RamChick
Hey Montec,
I'm new to the forum and have been browsing heavily. I'm a long time dodge enthusiast, but admittedly I have little knowledge on them. I'm looking at getting an 01 1500 , and I posted a seperate thread asking for advice on what to look out for if I happen to go look at it/test drive it.
What I would like to ask is, I know it's probably a lot to ask, but can someone explain the tranny issues that people keep mentioning. I don't mean in depth, I don't want to keep you here all night, but in general. Like I said I'm thinking about going to take this one for a spin, and I know the basics, but with the tranny problem in particular, what questions do I ask the owner, what do I look for on the service records if I can get ahold of any, what do I look out for when test driving? Also, I know it probably sounds like a stupid question, but will I usually notice if the tranny's going to give up on me? Say I test drive it and notice no shifting difficulties, good fluid, whatever else, can I say it's safe until I see certain signs or is it one of those things that might or might not go out one day at random?
Everything I've read and everyone that's talked to me on my other post has said to just expect I'll need a rebuild sooner or later, so I understand that much.. but I don't want to go from a decent car that I have little worry with from day to day, to something I'll have to constantly keep my eye on. I want to baby it, but I'm not looking at big hospital bills if you know what I mean! haha. Just some tranny wisdom would be helpful. I've been trying to do some reading on my own, but I can't find the information I need in one place.
One option is to download the factory service manual in the faqs section here
https://dodgeforum.com/forum/2nd-gen-ram-faqs/236110-factory-service-manual-for-2nd-gen-rams.html
And in the transmission section it explains what to look for and to note on a test drive.
Then there is a section that lists possible causes and solutions to the problems.
Dave
Old May 31, 2010 | 12:36 AM
  #322
gearjammer95's Avatar
gearjammer95
Default Do I need a band adjustment?
1995 Ram 2500 with 5.9 automatic 4x4 with 3.55 gears I think. This was an old work truck I bought and tried pulling my boat today which weighs around 7,000 pounds. While accelerating with o/d off the RPMS seem to jump about a couple hundred RPMS just before it shifts. The transmission was rebuilt a year ago. But that was before I bought it.
I only went 2 miles with the boat. I used low range pulling up the steep boat ramp so I wouldnt strain it too bad. This is the first automatic I have owned in 10 years.
Could it need a band adjustment? I read somewhere max trailer weight is 8,800
Old May 31, 2010 | 12:48 AM
  #323
Gross Vehicle Weight Rating (GVWR) is 8800. Gross Combined Weight Rating (GCWR) is what you are looking for.... and I don't seem to be able to come up with it anywhere......
Old May 31, 2010 | 10:56 AM
  #324
gearjammer95
for the 2500 HD 8,800 with 5.9 liter GCWR is 14,000 and max trailer wt is 8,600
That is straight out of the origional owners manual that came with it when new
Old May 31, 2010 | 04:57 PM
  #325
MonteC's Avatar
MonteC
Originally Posted by kboyd38
Hey, I'm new to the forum and I've been searching through it trying to find a solution to my problem but so far i'm still out of luck. I recently bought a 98 ram knowing it had transmission problems. The guy bought a brand new transmission and put it in himself so I'm sure that has something to do with it. But it rarely shifts into 2nd, when it does I have to manually do it myself. Its shifts into 2nd when its cold but as it warms up it doesn't wanna shift at all and slips out of gear. I've adjusted the tv cable multiple times and it helped it get into 2nd but it still won't do anything else. Any suggestions?
Define brand new transmission?
Old May 31, 2010 | 04:58 PM
  #326
MonteC's Avatar
MonteC
Originally Posted by duxndogs
I have a 94 and it shifts fine and goes thru all gears but it feels sluggish i mean it just slips into the next gear not really crisp clean shifts.
What can i do to improve the shifting.
Fluid and filter were recxently changed.
Sonnax sure cure.
Old May 31, 2010 | 04:59 PM
  #327
MonteC's Avatar
MonteC
Originally Posted by J415
Hey Monte, well I've driven it for 112 miles since the rebuild, and now I don't have overdrive. Overdrive won't engage. Before that, everything was flawless. I did buy a remaned O.D. solenoid so I think that's the problem. I never over heated. Am I on the right path?
Hmm. Gotta be something simple. If you can get ahold of a scan tool see what the computer is commanding and what the transmission is actually doing.
Old May 31, 2010 | 05:08 PM
  #328
MonteC's Avatar
MonteC
Hey Montec,
Well its a used vehicle. Ive fought my battles with buying used cars and i still do today. It truly is hit or miss.
My advice for the transmission side is: Check the fluid, smell it. For reference smell a brand new bottle of atf+4, smell a bottle of Dex/merc 3. Compare it to the fluid in the truck you plan on buying. Odds are good that they have never changed the fluid. If the fluid smells burnt or off, or looks murky or off color, there is a good chance transmission problems are ahead.
If you can get service records that would be great, but understand that even the most meticulously maintained transmission can still have problems. DRIVE the truck, run it hard full throttle for a good while, get the truck nice and hot and beat on it. Any shifting issues should pop up if present.
And if the transmission was rebuild or replaced i would still be wary, lot of under qualified "transmission rebuilders" out there.
Good luck with your purchase.
Old May 31, 2010 | 05:13 PM
  #329
MonteC's Avatar
MonteC
Ok. When youre talking about a transmission i would go with the lowest rating. You have the 46re in your 2500, which is the same exact transmission in the 1500 trucks, nothing different at all. Yes the truck chassis is rated for more but that transmission isnt the best
To me it sounds like the transmission is flaring between shifts. If only the 1/2 shift is flaring i would say adjust the bands and see if it helps, but if its flaring between the 1/2 and the 2/3 then id say its a bigger trans problem. Or a bad rebuild.
Old May 31, 2010 | 09:30 PM
  #330
J415's Avatar
J415
That's the crappy part. My resource's are limited. Thanks for all your help. Here's a link to my thread regarding this.
https://dodgeforum.com/forum/2nd-gen...y-rebuild.html
