No Brake lights
Old Apr 11, 2010 | 06:03 PM
360mag45's Avatar
360mag45
Default No Brake lights
I have no brake lights other than the 3rd light. I have check the fuse, the relay on the pedel and the one under the hood. Could it be a possable ground or somthing else? Any one have this problem befor.
Old Apr 11, 2010 | 06:57 PM
360mag45's Avatar
360mag45
anyone out there
Old Apr 11, 2010 | 07:53 PM
master tech's Avatar
master tech
Site Moderator & Tech
Remove one of the rear brake lite bulbs and using a 12 volt test lite, ck for power at the sockets. If you have no power getting to the bulbs, start checking the wire harness under the bed. If you do have power, then ck the ground next. If you have both power and ground, replace the bulbs.
Old Apr 11, 2010 | 09:01 PM
ghost4321's Avatar
ghost4321
Could be the bulbs, I've seen both go bad a nearly the same time before.
Old Apr 11, 2010 | 10:35 PM
jasonw's Avatar
jasonw
Site Moderator
And for goodness sake, wait longer than 54 minutes for a response. Man, the impatience of some people.
Old Apr 12, 2010 | 06:46 AM
charlie1935's Avatar
charlie1935
Better to kick back and relax while waiting for a reply.
People that are always in a hurry or get uptight are the ones that have heart attacks.
