how do i identifiy a rear axle
Old Apr 14, 2010 | 06:18 PM
bikegod87's Avatar
bikegod87
Default how do i identifiy a rear axle
i have a 1999 dodge ram 1500 4x4 i blew the rear in it and trying to find out wat rear i have so i can try 2 find one at the junk yard
i dont know how to decode any of the #s on the rear the tag under the hood says the front ratio is 3.55 in a dana 44
any help will be apprecitaed
thanks
ben kauffman
Old Apr 14, 2010 | 06:47 PM
BIGRED97's Avatar
BIGRED97
well look at the truck, the one in the back is your rear axle....
but no sorry, haha you have the Chrysler 9.25 rear end, geared at 3.55. really if you could find a dana 60 off a 2500 then that would work too, just make sure that its geared the same as your front axle. or upgrade the gearing too.
Old Apr 14, 2010 | 06:52 PM
mike R's Avatar
mike R
I have the same problem with my new to me 98. I hope someone can help us both.
Old Apr 14, 2010 | 07:58 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
what rear did you blow. the front one or the rear one......ok pay attention here ill try to break this down
1500 models------- front = dana 44
rear = corporate 9.25
2500 models------- front = dana 60
rear = dana 70 with auto trans dana 80 with standard trans
3500 models------- are all dually's in the 2nd gen with a dana 60 front
anybody correct me if im wrong on that info
Old Apr 14, 2010 | 08:03 PM
dhvaughan's Avatar
dhvaughan
used 9.25's are a dime a dozen in junk yards. most, probably all, will have 3.55 gears.
check and double check but its very likely that the 9.25 from ram, ram van, dakota, durango are all the same. watch the year as the later models have the bolt up yoke on the drive shaft.
Old Apr 14, 2010 | 08:06 PM
dhvaughan's Avatar
dhvaughan
i'm not positive, but i think a 2500 with 5.9 engine had dana 60 in the rear. V10 and Diesel had D70 and/or 80
Old Apr 14, 2010 | 08:10 PM
xxxcowxboyxxx
yes that too is correct, forgot to add that
Old Apr 14, 2010 | 09:34 PM
jamesnb's Avatar
jamesnb
I'm pretty sure my 1500 came with a different rear axle than the 9.25. I'm not sure if it's because it's the "Off Road" edition or because it has the towing package
Old Apr 14, 2010 | 09:52 PM
VEETEN's Avatar
VEETEN
If it's the corporate 9.25 then the diff cover is octagonal, (looks like a stop sign)
Be Right Back
EDIT
Ok here is the DANA axle, What does your's look like?
DODGEPWR's Avatar
DODGEPWR
No your not special....These guys know what there talking about. You do have the regular ol 9.25
Take a pic of it....Post it up.
