Transmission question
Old Apr 17, 2010 | 06:25 PM
95 Jamin Ram's Avatar
95 Jamin Ram
Default Transmission question
My truck seems to hold gears for a while. What could be he cause of that? Fluid hasn't been changed in a while but its very clean and the fluid level is fine. Is there any good additive i could use to help fix this?
Old Apr 17, 2010 | 07:50 PM
MonteC's Avatar
MonteC
Try SMARTBLEND, in the red bottle. You may have a sticky governor.
Old Apr 17, 2010 | 09:52 PM
jasonw's Avatar
jasonw
Site Moderator
Are you checking the fluid level in park or neutral? Cold or warm?
Old Apr 18, 2010 | 12:23 AM
GeorgiaDodge's Avatar
GeorgiaDodge
mine did the same thing, dropped the pan, flushed everything and did a filter and havent had a problem since
Old Apr 18, 2010 | 06:36 AM
95RAM360's Avatar
95RAM360
do a fluid/filter change. I noticed a great change in my shifting, and found my filter was all gunked up...
Old Apr 18, 2010 | 10:25 PM
95 Jamin Ram
I usually do i when its in neutral and warm. Ill try finding some smart blend then if that doesn't work ill change the filter and fluid. That smart blend does mess anything up right?
Old Apr 19, 2010 | 12:19 AM
dodgeram07's Avatar
dodgeram07
i would do the filter and fluid frist (unless if you have done it recently)
SMARTBLEND will only help
