permanently locking CAD
Old Apr 17, 2010 | 11:38 PM
1994ram1500's Avatar
1994ram1500
Default permanently locking CAD
I'm having alignement problems with the two shafts on my CAD. I am thinking about just sliding the collar over and permanently locking the CAD in place. I'm thinking with an open diff this should be okay? has anybody tried this with success? i know it will probably turn the front driveshaft too but when the t-case is in 2wd t should be fine right?
Old Apr 18, 2010 | 12:00 AM
97tn4x4's Avatar
97tn4x4
I guess you could but you're going to burn alot more gas. What exactly are you having problems with on the cad?
Old Apr 18, 2010 | 12:05 AM
1994ram1500
bearings and/or seals are shot, the two half-shafts are not lining up, causing the collar to bind and not lock in. I dont really drive the truck much or for long distances so thats not a huge worry. if i'm not mistaken the 2002 3/4 and 1 tons did not have a CAD correct? so this would basically be the same thing?
Old Apr 18, 2010 | 03:36 AM
97tn4x4's Avatar
97tn4x4
if a bearing is worn out it turning all the time is only gonna make it worse. I still don't see how your axle shaft and intermediate shafts aren't lining up? But if the truck isn't your main source of transportation I don't see it being a problem.
Old Apr 18, 2010 | 06:17 AM
95RAM360's Avatar
95RAM360
make sure the whole front end doesnt end up locking up. I would NOT lock the shafts IMO
Old Apr 18, 2010 | 07:12 AM
zman17's Avatar
zman17
Retired Moderator - RIP
In the photo, the intermediate shaft bushing is on the right and the smaller bushing on the left goes in the end of the outer shaft . These are not that hard to replace.
Old Apr 18, 2010 | 08:09 AM
1994ram1500
i need a set of those ^^. Where can i get them? Thanks alot!
Old Apr 18, 2010 | 08:14 AM
zman17's Avatar
zman17
Quad4x4.com the larger bushing/bearing is available in metal also.
Old Apr 18, 2010 | 08:23 AM
dhvaughan's Avatar
dhvaughan
nice pictures. i have a similar problem, although it will eventually slide with enough attempts.
zman - if your not replacing seals or u-joints, what is the minimum amount of steps to replace them both?
if anyone finds a link for parts, post it in here to help everyone else.
Old Apr 18, 2010 | 08:32 AM
zman17's Avatar
zman17
You still have to remove the outer axle or at least slide it out a small amount to replace the smaller bushing only. Installing the larger bearing requires removal of outer and intermediate shafts. Which is not much more than doing a ujoint or seal for that matter, and both parts install easily with no special tools required.
