how 2 get cel code?
My CEL light is on again it cost me 25 bucks to have it read i have heard there is a way to check your self from what i have seen on here but noone says how i turning the key on off three times but it dont flash on the 4th time. i moved my plug wires now its running better but the light came back. my cat is hollow so its not plugged. i just want to get a code from it and run it by u guys. any help?
https://dodgeforum.com/forum/2nd-gen...c-display.html You've done it like this in the vid right? and your truck gotta be OBD11 I believe
Worked on my 01. OBDII
Are you turning the key all the way back to the removal (lock) position?
Trending Topics
If your cat is hollow, thats what your code is. Mine's the same way and I get code P0420 (Low Catalyst Efficiency) every once in a while. If I don't clear it with my scanner it will go away after a week or 2. Do you remember what code you had last time you checked it?
And the key trick should work for you. I have a buddy with an 01 2500 and he's the one who showed me the trick in the first place. And most people here can do it I think, except for me it seems
