swap 96 5.2 into 99 5.9
Old Apr 19, 2010 | 10:55 PM
01ramjam's Avatar
01ramjam
Default swap 96 5.2 into 99 5.9
Ok so my motor in my 99 is a 5.9 and it is pretty much shot. My question is can i swap a 5.2 out of a 96 into it withouth having to change computers or anything like that?
Old Apr 20, 2010 | 12:02 AM
edlucky1's Avatar
edlucky1
Im pretty sure that you need the computer I have seen on several swaps the other way that you need it. Also check about your transmission, I know on the older magnums I think L.A. style, the trannys were different from the 5.2 and 5.9.
Old Apr 20, 2010 | 12:07 AM
J415's Avatar
J415
The toque converters on a 5.9 were weighted and on the 5.2 they were not. That definitely would ave to be changed. Also you 99 Ram is an OBD II engine, were as your 96 is an OBD I. Save yourself the headache and don't do it. To much work.
CPTAFW163's Avatar
CPTAFW163
pretty sure the tranny's are thesame for the engines. 1996 they started with a different tranny (RE) and 1994/95 they had the RH. I think.
It should work, but just keep your old PCM and hook it up...see if it works. Also, take the fuses out of the old truck and put them in the new one. I know the fuses are different.
Old Apr 20, 2010 | 12:25 AM
01ramjam's Avatar
01ramjam
Thanks for all the info i guess i will just head to trade it off dont really have the money to buy another engine but had this one laying around and dont really want to get into something that i cant fix.
Old Apr 20, 2010 | 12:29 AM
CPTAFW163's Avatar
CPTAFW163
it would not be hard to find a 5.9. It does not matter what year it is. The only thing that would change are maybe the AGR and other smog equip on the intake. You basically need to take everything off the old intake and put it on the new one.
You can get a 5.9 engine installed for about 750 bucks from a junkyard.
It is easier than you think.
Old Apr 20, 2010 | 03:33 AM
dakotas ram's Avatar
dakotas ram
keep your intake and sensors and it should be a pretty easy swap...computer should be changed to a 99 5.2, but i dont think it will hurt to run your current one
Old Apr 20, 2010 | 07:04 AM
95RAM360's Avatar
95RAM360
you could score a computer at the right junkyard for cheap.
