ABS & Brake Light Help
Old May 25, 2010 | 01:50 AM
  #41
99dodge318's Avatar
99dodge318
you should not buy sensors from autozone, o'rileys, or pep boys, they are made from very cheap materials, and do not last long.
spend a little more money and buy a dealer replacement.
Old May 25, 2010 | 11:23 AM
  #42
bigtman07's Avatar
bigtman07
I haven't had a chance to bleed mine yet but I think that is what is causing the issue.
Old May 25, 2010 | 10:04 PM
  #43
bigdog2005's Avatar
bigdog2005
Originally Posted by 2robinhood
Did it fix it ?
Hows things working now ?
Just sent it out last Saturday so I should be getting it back by the end of the week. But I have been driving and now the speedo is out. Hopefully it kicks back on when the ABS Module is reinstalled.
Old Aug 17, 2010 | 08:19 PM
  #44
W8 a minute's Avatar
W8 a minute
Any update? I just spent 70 bucks to have the dealer tell me it would be around 800 bucks to replace the defective module. The part alone was $560.
Does O'Reilly, Autozone, etc carry these? I'm tempted to buy a used one but it seems kinda odd to buy a used module from a truck that's been wrecked and obviously couldn't stop in the first place.
Old Aug 17, 2010 | 11:23 PM
  #45
CBR900RR19's Avatar
CBR900RR19
Module Master rebuilds yours for you and you can have it back in about week from the day you ship it to them. Cost me 153.00 for everything including shipping and you get a 5 year warranty...
http://www.modulemaster.com/en/index.php
Old Aug 18, 2010 | 06:51 AM
  #46
Signal 2's Avatar
Signal 2
Originally Posted by dhvaughan
brake and abs light is usually the speed sensor in the top of the rear diff. in the parts catalog its sometimes called rear abs sensor. its probably not the 'speed sensor which is in the tail housing of the trans.
since it comes and goes, you might unplug/replug the connection, remove/check the sensor. its just a magnet but it might have a bunch of **** stuck to it.
^This. About $40 IIRC and it cured both the ABS and BRAKE dash lights I had until a few weeks ago.
The diagnostic reader couldn't specify exactly which sensor...not sure now, but I think it mentioned one on the transmission as being a possibility too. I took a chance on the ABS sensor. Less than 10 minutes to change. Be sure to clean/wash around it well before pulling the old one off. Lubricate the 'O' ring and re-install.
