ABS & Brake Light Help
Old Apr 20, 2010 | 10:02 PM
florida9's Avatar
florida9
Default ABS & Brake Light Help
The ABS & Brake Light come on sometimes when i start the car if i turn it off and back on a few times it will go away my speedometer is working but its off by 5mph i think its because my tires are a little bigger then normal so i don't think it is the sensor i have a 1998 Dodge RAM 1500 Pickup 5.9L V8 Magnum it has 155,554 Miles any suggestions would be great
Old Apr 20, 2010 | 10:36 PM
yakkier's Avatar
yakkier
Might be a speed sensor problem, i have 33's which are quite bigger than stock and my speedometer isnt off more than 1 mph.
Old Apr 20, 2010 | 11:03 PM
florida9's Avatar
florida9
I Got 265 i think it was they are 16's and its off by 5mph which sensor you think it would be front or back its 2wd i don't know if it matters
Old Apr 20, 2010 | 11:23 PM
dhvaughan's Avatar
dhvaughan
brake and abs light is usually the speed sensor in the top of the rear diff. in the parts catalog its sometimes called rear abs sensor. its probably not the 'speed sensor which is in the tail housing of the trans.
since it comes and goes, you might unplug/replug the connection, remove/check the sensor. its just a magnet but it might have a bunch of **** stuck to it.
Old Apr 20, 2010 | 11:26 PM
florida9's Avatar
florida9
Okay thanks i will check that in the morning if its not raining
Old Apr 21, 2010 | 10:26 AM
florida9's Avatar
florida9
I went under the truck this morning and i think i found it i really do not know what it looks like but here is a picture of what i think it is
Old Apr 21, 2010 | 12:43 PM
bigtman07's Avatar
bigtman07
Yup you got it. Its not a really expensive part. So it's worth a shot to replace it. If it works let us know. I have the same issue but I replaced the diff sensor now it comes on randomly. So I'm curious to see what else it could be. Where is the sensor that is on the tranny? Is it easy to get to?
Old Apr 21, 2010 | 03:57 PM
florida9's Avatar
florida9
Well it was a B**** to get out but i got it as you can see there was a lot of crap stuck to it i got it all off and the speedometer is off by only 2-3 MPH Instead of 5 but i don't know about the light yet as it comes and goes should i try and replace it?
Old Apr 21, 2010 | 08:16 PM
seabass202's Avatar
seabass202
I may be mistaken, but isn't there supposed to be a little square piece of metal sticking out of that a bit? ( to get closer to the tone ring?)
Old Apr 21, 2010 | 09:12 PM
yakkier's Avatar
yakkier
eh some do some dont, the one on my ram doesnt but the one on my durango did
