loosing oil pressure
Old Apr 21, 2010 | 11:49 PM
Mopar_360's Avatar
Mopar_360
Default loosing oil pressure
im loosing oil pressure in my truck when i start it up it jumps to between 60-70 but when i drive it, it drops down to 10psi. its not the sensor because i was using a gauge i ran up through the hood to see if that was it. so if its not that what could it be im changing the pump tomorrow to see if thats it
Old Apr 22, 2010 | 12:11 AM
JackJ's Avatar
JackJ
I would say you are going the right direction there. But the only question I have is, are you referring to a direct pressure gauge or another electronic one you put in.
Old Apr 22, 2010 | 12:53 AM
dhvaughan's Avatar
dhvaughan
i'm guessing oil pump. check the pickup screen and pipe carefully, and don't forget to prime it. if your rear main is leaking, they'll never be a better time to fix it.
Old Apr 22, 2010 | 11:42 AM
Mopar_360's Avatar
Mopar_360
i used a direct pressure gauge. but now i cant put the pan back on because i found 3 holes in it
Old Apr 22, 2010 | 11:51 AM
JackJ's Avatar
JackJ
Then I must say 3 of my favourite words.
TO THE JUNKYARD!!!
Old Apr 26, 2010 | 12:21 AM
dhvaughan's Avatar
dhvaughan
my favorite 3 words. J B Weld.
Old Apr 26, 2010 | 02:14 AM
Gerehead8's Avatar
Gerehead8
If the truck runs up to 30+ PSI at 3k rpm then it is is just fine. Curb idle is about 7psi minimum and they are supposed to be at 30-80 PSI at 3k RPM. If it is within that range don't bother with it.
Old May 5, 2010 | 11:51 AM
Mopar_360's Avatar
Mopar_360
i pulled the old motor yesterday and today i took the intake and valve covers off and there was anti-freeze right under my intake. On my intake what is that pan on the bottom of it for
Old May 5, 2010 | 12:12 PM
95RAM360's Avatar
95RAM360
thats the PLENUM.....
it may be because of a bad intake gasket, and the coolant passage is able to seap into the galley.
Old May 5, 2010 | 07:06 PM
dhvaughan's Avatar
dhvaughan
when you remove the intake, its normal for coolant to leak out into the lifter valley.
