stupid 46re
Old Apr 23, 2010 | 02:06 PM
gevalco207's Avatar
gevalco207
Default stupid 46re
Hey guys first thread. I have a 98 ram 2500 5.9 360 long box 2x4 i bought a year ago the guy said the tranny was rebuilt 35,000 ago havent had any luck with it. Right now if i floor it it will redline its like it gets loss in between gears and rough/high rpm shifts. sorry if there is a thread about this already.
Old Apr 23, 2010 | 02:09 PM
J415's Avatar
J415
So other then that, it's fine, or what? If that's your only problem then there's a simple fix for it. Here's the thread:
https://dodgeforum.com/forum/2nd-gen...ng-issues.html
Old Apr 23, 2010 | 03:34 PM
gevalco207's Avatar
gevalco207
Thanks man I will be getting that looks pretty easy I'm not much of a tranny guy I think I should beable to figure it out. I got a question for you I have I vacuum port on the drivers side on my intake manifold and It has a screw shoved in it right now any idea. Thanks agin
Old Apr 23, 2010 | 08:18 PM
J415's Avatar
J415
Click on the link: https://dodgeforum.com/forum/2nd-gen...d-vents-4.html
Assuming you have the same set up as post #61, where do you have a screw in the vac hose.
Old Apr 23, 2010 | 08:37 PM
gevalco207's Avatar
gevalco207
Yes thats it but on the drivers side. It just as a short 1" line that is pluged with a screw. Should i just put a reguler vac port plug or should it go some where.
Old Apr 23, 2010 | 09:08 PM
J415's Avatar
J415
On the drivers side there 2 ports. one on top of the other. One is for the brake booster and the other is plugged. It doesn't matter which one is use and which one is plugged. I think the previous owner couldn't find a legit plug, so he jerry rigged it.
Old Apr 23, 2010 | 09:13 PM
gevalco207's Avatar
gevalco207
ok thank alot i will get it pluged right thats so funny the guys name was jerry.
Old Apr 23, 2010 | 10:00 PM
J415's Avatar
J415
Well there you have it!
