Seafoam Treatment!
Old Apr 25, 2010 | 04:55 PM
  #21
yakkier's Avatar
yakkier
It's simple dude, the Brake booster is an open hose, the PCV is a valve which sucks it up into the system, the brake booster hose is larger and doesnt get it as deep into the system as the PCV does. IE it's like using a water hose vs using a spray bottle.
PCV speads it a little more evenly inside the intake and the brake booster doesnt create as much vaper as the PCV does.
Use whatever you want im just saying i use the PCV and not the brake booster and have seen better results because of it, i have no charts or breakdowns to prove it does a better job but seafoam even states on their website that the more smoke/fog you see the more carbon that is being removed/flushed from the system. i have done this on my truck my wifes truck and a **** load of other cars/trucks iv owned in the past and i have always seen a difference in between using the PCV over the booster.
And judging by the posts from other members and their experiences im not the only one.
Originally Posted by Laramie1997
Yak, prove to me how fogging the intake via the brake booster does nothing? It all goes to the same place and IE, it fogs. Fog means light mist in which case there would be no puddling. Just show me how and why you think this to be so.
To the OP, you can pull the PCV valve and do it there or just take the air hat off and pour small amounts of it down the TB blades manually operating the throttle there to keep her running. Personally, I don't buy into the idea of putting it in your oil. Just fog the intake and put the rest in your gas if you want but even that's not required.
Old Apr 25, 2010 | 07:56 PM
  #22
Laramie1997's Avatar
Laramie1997
Well, that's all fine and well, but it's not going to pool in the intake like you think. It will still fog just fine. These trucks already move a lot of air at idle and if you rev up to about 2K then even pouring it into the intake will fog it out like you want.
Old Apr 25, 2010 | 09:58 PM
  #23
aim4squirrels's Avatar
aim4squirrels
I preferred the Mopar Combustion Chamber Cleaner myself.
Since I went strictly to chevron gas about 2 years ago, I don't get much smoke with any cleaning products anymore.
Old Apr 25, 2010 | 10:47 PM
  #24
bekins01ram's Avatar
bekins01ram
I'm not sure if this is proof, but it changed my mind.
Two weeks ago I seafoamed my truck with the brake booster line.
When I took off driving, I got 1 large puff of smoke, then it slowly diminished
Yesterday, after reading this thread, I used the PCV valve hose. You wouldn't think it'd smoke much, since it was only two weeks ago I did it with the booster hose. Well this time, I got large smoke clouds thru 8-10 revs of the motor, and it diminished much slower than it did last time.
So, in my eyes, I think the pcv hose is the way to go. Makes sense that it would disperse it more evenly thru a smaller hose.
I posted this in another thread, too, but you wouldn't think it'd smoke this much, if the carbon had been cleaned out the first time.
Old Apr 27, 2010 | 12:10 AM
  #25
Nando Vazquez's Avatar
Nando Vazquez
I used the PCV valve instead of the booster. I got a **** load of smoke, I guess those almost 200,000 miles did some work on that engine. I got incredible results, better throttle response, acceleration, and I havent checked the MPG yet. She idles alot smoother and is running great.
Old Apr 27, 2010 | 01:11 AM
  #26
Gerehead8's Avatar
Gerehead8
When using SeaFoam you will not notice results the first round. I did 1/3 of a can in three seperate applications before I noticed an improvement. FOLLOW THE INSTRUCTIONS ON THE CAN TO THE LETTER. The results are much better.
The arguement between the pcv and breather hose is just dumb. The fluid flows to the same spot, under the same vacuum ect. You are supposed to pour it through the TB anyway, the hoses just make it easier.
I really doubt the cleaning the intake is where the improvements are made. I am going to guess that none of you have seen the back of an intake valve after the plenum has been blown for awhile. When I tore down my 360 (out of a 2500 with 100k and had a blown plenum) I could not believe the amount of carbon on the back of the valve. There was easily an 1/8 of build up to maybe 1/4 in the middle. I had to scrape it off with a puddy knife and a razor blade before I could clean the valves. With that much carbon flow is significantly reduced. I would bet that the sea foam (throughly vaporized by now no matter how it got in the intake) starts to dissolve the carbon and by the third application it is breaking up and flowing into the cylinder and out the exhaust causing the mass amounts of fumes.
Belkins the reason it smoked more is because it was your second application. Not becuase of how you got the fluid in there a different way.
Old Apr 27, 2010 | 01:38 AM
  #27
Laramie1997
That was the point I was trying to make, but I chose to let the challenger arrive at the conclusion himself.
Old May 23, 2010 | 06:59 AM
  #28
M Laborde's Avatar
M Laborde
How long should you wait between uses (via the PCV) for best results?
Old May 24, 2010 | 11:46 AM
  #29
Nando Vazquez
I waited about a week before I put another can in. I put 1/3 of the can in the gas tank, oil, and intake the first week.
1/2 a can in the intake and gas the next as you have to change your oil right after putting seafoam into the crankcase.
The real improvement is felt after the second application or even third application.
Old May 24, 2010 | 02:06 PM
  #30
DukeSupes's Avatar
DukeSupes
So what does Seafoam do in the crank case to where you have to change the oil within 100 miles?
