how much should i hall? asap
Old Apr 26, 2010 | 03:20 PM
townsley4's Avatar
townsley4
Default how much should i hall? asap
Hey, I've been doin a lot of landscape work,and I've been hauling mulch and sand/dirt. I got to pick up some lava rock. I calculated around 25 bags of the lava rock pebbles. They are like 45-50lbs a bag. Would it be ok to haul that many? Truck sagged with 15 bags of mulch.... 01 ram 1500 5.2 gotta go about 40 miles. Don't really want to make 2 trips,
Old Apr 26, 2010 | 03:44 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
25 bags times 50lbs/bag = 1250lbs. Can your rear springs/shocks and brakes handle that?
Old Apr 26, 2010 | 04:51 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Umm yea I had 1700-1800 lbs of bed weight in mine but than agin I have another leaf in the pack and drove like a snail. Was I over loaded yes! But was I cautils driving with out a question in my mine. I doubble my breaking distance.
Old Apr 26, 2010 | 05:45 PM
dodgeram07's Avatar
dodgeram07
Ya I had 1300 in the back of mine it worked out ok...... Still had about a inch till the bump stop
Old Apr 26, 2010 | 05:47 PM
ophidia's Avatar
ophidia
I went to get some pea gravel. They said that they would only put 2/3 of a yard in there, 1800 lbs. The driver accidentally put a full yard in there, 2700 lbs. There was some suspension travel left, but not much! Would I recommend this? No. One good thing that came of it is my truck doesn't sag on the driver's side anymore.
Old Apr 26, 2010 | 05:55 PM
dhvaughan's Avatar
dhvaughan
you can haul 1250 easy. stopping will be difficult, so go slow and plan ahead.
Old Apr 26, 2010 | 06:33 PM
hammerhead1985's Avatar
hammerhead1985
make sure of the load rating on your tires too. and that they aren't cracked or dry rotted....
Old Apr 26, 2010 | 07:58 PM
redheadhunter21's Avatar
redheadhunter21
+1 on checking tires, Make sure the air pressure is ok on the tires, and kept it slow and steady
Old Apr 26, 2010 | 08:00 PM
Relex's Avatar
Relex
Last year a few times I had to haul 5 square of shingles which is about 1350 pounds. I just took it nice and slow and left plenty of room for stopping.
1027090839-00.jpg?t=1272326010
