Fixing the Plenum, with out using the hughes kit. :(
Old May 1, 2010 | 05:23 PM
JackJ's Avatar
JackJ
Angry Fixing the Plenum, with out using the hughes kit. :(
Well, I was planning on ordering the hughes kit for this weekend but I lost my billing address, due to friends moving and not having time to fix it due to work. I don't have an actual mailing address either.
I was going to to just go buy a new gaskete for now and see if that will make any difference. Was just wondering if doing that for now until I can get a new shipping and billing address set up is actually worth it, and if I will see any change. I have a feeling mine is shot and prolly never changed, I got carbon build up on the TB last time I looked and I can barely brake free my 32's.
Old May 1, 2010 | 05:30 PM
98formulaLS1's Avatar
98formulaLS1
you will see a change, it will fix it for now. BUT, it's inevitable that the gasket will break again. And it's quite a job too. I recommend that you only do it ONCE. btw, I just did mine too, and I used the Hughes kit. Went perfect.
Old May 1, 2010 | 05:33 PM
yakkier's Avatar
yakkier
I would wait man, im waiting i'v got the gasket already i just need the plate and i'v been tempted to just replace the gasket for the time being but iv weighed the pros and cons and honestly i dont want to break into the engine to replace it knowing i have to do it again in another 10k miles or sooner.
Old May 1, 2010 | 05:45 PM
JackJ's Avatar
JackJ
I know I should wait, but I am having a fix it day on my truck tomorrow, doing ball joints on the right side, and I'll already have it in the shop on base.
Old May 1, 2010 | 05:47 PM
yakkier's Avatar
yakkier
it's gonna take more than a day if you're doing balljoints ontop of the plenum, plenum is gonna take you 4 hours atleast if it's the first time you've ever done it.
Old May 1, 2010 | 06:13 PM
95RAM360's Avatar
95RAM360
ID WAIT....it would be pointless and a waste of money if you just got a new gasket
Old May 1, 2010 | 08:00 PM
DukesOfHazzard's Avatar
DukesOfHazzard
Could they ship it to a nieghbors , friend, base , shop... i would do that for someone if i could...
Old May 1, 2010 | 08:22 PM
revvinram's Avatar
revvinram
Well I had mine replaced a few years back before I was a member here and knew about the updated plenums, all they did with mine was send the intake to the machine shop to check it for cracks and make sure the surfaces were flat on it, and replaced the plenum bolts, intake bolts and gaskets along with ultra copper gasket sealent. Its the same way he has always done these Dodge Rams and also his own personal Ram, he said he only had one issue in 13 yrs and that was because the intake was no good, but anyways I have over 32 thousand miles on my plenum since it was done, with no issues..
Just my two cents.. your opinions will vary!!
Old May 1, 2010 | 08:31 PM
Maxx_Magnum's Avatar
Maxx_Magnum
My one suggestion if you are gonna just do the gasket: Go and get new plenum bolts that are a little shorter than the stock ones. It would be interesting to see if that alone makes any difference in gasket life... and it's a cheap fix to one of the known problems with these motors
Old May 1, 2010 | 09:04 PM
98formulaLS1
also, one important thing to mention is MAKE SURE YOU TORQUE TO INCH POUNDS and NOT FOOT POUNDS!!!! I learned that the hard way.
