Power locks not working.
Old May 4, 2010 | 09:36 AM
sk8erdude's Avatar
sk8erdude
Default Power locks not working.
so i got into my truck the other day and my power locks dont work. the passenger side will lock the locks but wont unlock them, and the drivers side wont do anything. i checked the fuse and its ok. i took off the door panels and cleaned/checked the switches. what else could it be?
Old May 4, 2010 | 12:04 PM
dodgeboy1979's Avatar
dodgeboy1979
I had the same problem and it was the switch itself
Old May 4, 2010 | 12:31 PM
Flue's Avatar
Flue
How did you clean the switches? I always use 220 grit emory cloth on the contact points. You can't take them apart, but you can put a strip between the contacts and sand the oxidation off. Cleaned the passenger side last summer, was out of 220 and ended up using 2000....talk about a long process. lol
Old May 4, 2010 | 12:36 PM
I just went to the local pickandpull, and grabbed a new switch. well, new to me anyway.
Old May 4, 2010 | 12:39 PM
98formulaLS1's Avatar
98formulaLS1
let us know if it works. If it doesn't, I would take a glance at the wires behind the fuse panel. I have found that the power window wires can melt easily, in which case will cause a break in the wire somewhere.
Old May 4, 2010 | 11:02 PM
sk8erdude's Avatar
sk8erdude
yea i sanded each of the contacts down with sand paper. but how could the passenger side unlock it if the wires melted? wouldnt that blow the fuse? and if i got new switches, where do you disconnect and connect the new ones? i dont remember seeing a plug.
