engine issues! swap to 5.9?
Old May 4, 2010 | 12:43 PM
quadracer18's Avatar
quadracer18
Default engine issues! swap to 5.9?
So i took my truck to the garage for the check engine light. Turns out My rings are gone in cylinder 7 and theres no compression. I found a few 5.2 and 5.9 engines on craiglist for $375-750. Is this a good price range?
My truck has the 5.2 liter. Can i do a direct swap if i find a deal on a 5.9? Does EVERYTHING swap over or do i have to customize anything to work??
Realistically, do you guys think i can sell my 5.2 with a bad cylinder 7 for anything to make back some of my money??
Thanks!
Old May 4, 2010 | 12:58 PM
Not sure if all the sensors/connectors are the same, but, the 5.9 should bolt right in. Have to reflash the PCM for the larger displacement engine though.
Buying a used motor is a crap shoot. You are never sure just how many miles are on it, don't know if it has any problems, (unless you can hear/see it run before it is yanked) and may end up with worse problems than what you already have..... (I yanked a blown motor, installed the used one that I got a 'good deal' on, only to find that my 'good deal' motor had a rod knock......)
Old May 4, 2010 | 07:07 PM
dhvaughan's Avatar
dhvaughan
before you give up on your old engine, i'd guess that your low compression problem might be a cracked head, blown head gasket, or bad valve, more so than bad rings. the lower end of the 5.2 and 5.9 are very durable, while the top end suffers a more normal rate of failure.
you might ask how it was determined that it was the rings, rather than the head.
and you should get a second opinion.
if you do swap the 5.2 for a 5.9, you have to swap the computer, and something about the flex plate or torque converter?
Old May 4, 2010 | 07:39 PM
Gerehead8's Avatar
Gerehead8
The differences in the motor are the computer, and the internal balance of the 318 and the external balance of the 360. Do a search and you will find your answers. I have posted this info before so I know it is out there.
By the way the 5.2/5.9L swap info should be put in the FAQ if it isn't already.
