fog lights not working
Old 05-12-2010 | 01:52 PM
DM6156's Avatar
DM6156
I twisted the wires together. did a little solder job. covered in heat shirnk tube. Covered with small flex tubing, covered that with larger flex tubing and electrical taped that shut! Looks like there was a similar break that was repaired near by. I picked this truck up used so I dont have full history.
- Dan M
  #22
Old 05-13-2010 | 12:14 AM
DM6156's Avatar
DM6156
it gets better. So tonight my instrument cluster lights would't come on. Fun driving home at night not knowing how fast you're really driving. They worked yesterday.
Swapped out the new switch with the old one, they work again. Man I love buying new parts that fail within a few days.
- Dan M
  #23
Old 05-13-2010 | 12:55 AM
- Dan M
Try doing it with distributor caps.
At least the old switch is still good. You can take the new one back, and put some money back in your pocket.
Are we having fun yet?
  #24
Old 05-13-2010 | 01:54 PM
DM6156's Avatar
DM6156
That's exactly what I'll be doing.
Odd stuff like this always seem to happen to me.
I need to learn more about electrical systems! That is definately a weak point for me. It's hard because about everything is electrical these days.
- Dan M
  #25
Old 10-22-2010 | 03:18 PM
SunhawkRam's Avatar
SunhawkRam
Default Fog lights
I am kinda having the same issue. I can hit my switch for the fog lights and they will come on. Once I let go of the switch, it will disengage. Should I just replace the switch or what else could be the problem?
  #26
Old 09-10-2013 | 11:48 AM
trailer_ron's Avatar
trailer_ron
do u have wireing diagram for fog lights on 2007 dodge nitro
  #27
Old 09-10-2013 | 12:02 PM
This is second gen dodge ram..... might wanna post in the Nitro forums.....
  #28
Old 03-14-2024 | 11:21 PM
Rebel_ram's Avatar
Rebel_ram
Default Can anyone help me
My truck is wired for foglights has the wires that t off under the radiator core support by steering box go up to fuse block underhood behind battery on the top of fender ive got the 15 amp fuse and both relays i just ordered off ebay the factory foglight button that sits next to the o/d button for the life of me cant figure where the harness plugs into the switch and i own a 1996 dodge ram 1500 laramie slt 4x4 cant find harness that goes into the factory foglight switch on dash needin help of where it would be
  #29
Old 03-15-2024 | 08:22 AM
That post was from 10 years ago. You would be better off starting your own thread instead of resurrecting decades old threads.
Quick Reply: fog lights not working
