Need some help with steering column
Old May 9, 2010 | 08:22 AM
jpbalt's Avatar
jpbalt
Default Need some help with steering column
I need a little help from you guys. The next time you're under the hood, take a look at the steering column where it passes the shock tower. Let me know how much clearance you have between the column and tower. Mine is rubbing and I'm trying to figure out a solution. The steering column doesn't have excess play in it, so I may have to get creative and move the steering box or something.
Thanks.
Old May 9, 2010 | 11:23 AM
96 3/4 ton, but, went and looked... there is at least an inch of clearance between the shaft, and the shock tower, gets closer to the frame where it passes over, than it does to the shock tower, and there is a formed in dent in the frame. (factory) If yours is rubbing, something is bent.
Old May 9, 2010 | 11:42 AM
moparman318's Avatar
moparman318
2000 dodge ram 1/2ton i got 3/4in
Old May 9, 2010 | 11:51 AM
Maxx_Magnum's Avatar
Maxx_Magnum
brb goin out to look, but I know it isn't close to rubbing the tower... you got issues somewhere buddy I would say
edit: lots of room on mine, good inch or more I would say...
Old May 10, 2010 | 09:25 PM
jpbalt's Avatar
jpbalt
Found out that my truck was wrecked before I bought it. The firewall wasn't straightened all the way and that's why its rubbing. I'm going to try to pull it out at my buddy's body shop. Thanks for the help.
