Engine Failure
Old May 9, 2010 | 11:30 PM
kikidbird's Avatar
kikidbird
Default Engine Failure
I was on the Freeway and then all in a sudden my oil pressure dropped to zero. Before I could have reacted, I loss engine power and then she started to knock. I pulled the engine out to evaluate the situation and discovered that the oil pump shaft had snapped off. The front three connecting rods show signs of overheating. Do you think I should rework the connecting rods or just replace them?
Old May 9, 2010 | 11:32 PM
PurplDodge's Avatar
PurplDodge
How much does a new connecting rod cost vs. reworking it?
Old May 9, 2010 | 11:45 PM
Replace them. Get them balanced as a set with the new ones.
Old May 11, 2010 | 03:49 PM
charlie1935's Avatar
charlie1935
If the rods show visible signs of getting too hot (I assume they are discolored from heat which would probably weaken them) I would replace them.
Old May 11, 2010 | 06:04 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
i wouldnt even second guess it, replace them
Old May 11, 2010 | 07:09 PM
kikidbird's Avatar
kikidbird
Thanx for the suggestions. I am going to replace the Crank and Rods.
