97 ram 1500 gear question?
Old May 12, 2010 | 08:56 PM
bdjordan's Avatar
bdjordan
Default 97 ram 1500 gear question?
My buddy has a 97 dodge ram 1500 4x4. It came with tow package and LSD. What would have been a standard gear for that year with tow package? We looked in the glove box and it is not there. Looked on the rearend itself and cannot tell.
Old May 12, 2010 | 09:05 PM
Best bet is to send an email off to chrysler, and get the build sheet for the truck.
Other alternative, is to pull the rear diff cover, and on the ring gear somewhere, it will list the number of teeth on the Ring and Pinion gears, divide the larger number by the smaller number to get your ratio.
Old May 12, 2010 | 10:10 PM
mrfarrell's Avatar
mrfarrell
either 3.92 or 3.55 it could go either way..
Old May 12, 2010 | 10:21 PM
HammerZ71's Avatar
HammerZ71
I used to think that factory tow automatically meant 3.92s. My '98 was, but I have found that is not always the case. So yep, best bet is to get the build sheet...
Old May 12, 2010 | 10:43 PM
redheadhunter21's Avatar
redheadhunter21
Is the under hood tag still readable, should tell you the gears and that its a LSD
Old May 12, 2010 | 11:59 PM
I have the tow package, and 3.55s.......
