motor swap 94 5.2 to 98 5.2
Old 05-17-2010 | 11:01 PM
1raiderfan77's Avatar
1raiderfan77
Exclamation popping in keg
after the motor swap and all the crap that has to be changed, after disconnecting the egr valve i am getting a little poping noise coming from the keg when shifting from first to second has anyone had this problem after disconnecting the egr i did the plenum gasket repair before installing the motor it doesnt effect the running of the motor it just going to drive me crazy till i figure it out P.S. a motor swap from a 94 to a 98 is a pain in the @ss you gotta swap just about everything and i mean everything
Old 05-18-2010 | 02:14 PM
DODGEPWR's Avatar
DODGEPWR
Is it back firing threw the intake?
Old 05-18-2010 | 05:46 PM
1raiderfan77
Default popping through keg
yes it is backfiring through the intake (keg)and seem not to have any take off power
Old 05-19-2010 | 03:24 PM
dhvaughan's Avatar
dhvaughan
backfiring through the intake can be a timing related problem, which can occur from damage to sensor or wiring of crank position sensor and cam position sensor. crank sensor is often damaged in engine removal/replacement. cam sensor wiring is sometimes damaged in intake replacement. no personal experience, but a lot of people complain about non dealer crank sensors not working right.
another thing to consider is fuel sync. if the distributor has been out, or been moved, then fuel sync needs setting with an expensive scanner tool.
