Misses when given alot of throttle?
Old May 18, 2010 | 08:30 PM
1998ram5.9's Avatar
1998ram5.9
Default Misses when given alot of throttle?
So its an off and on problem, starting like 4 months ago. I will give it about half throttle and it seems like it will die for like a second, then it kicks me back in the seat and runs good. But then sometimes it will not do it for 2-3 weeks. could my cat, that i still havent gutted yet, cause this or should i look at other things
Old May 18, 2010 | 08:46 PM
lastrights's Avatar
lastrights
ya i would say your cat is bad, i would do a tune up too if you havnt done it in a while
have you noticed this before you done your plenum , if so it prob clogged your cat
Old May 25, 2010 | 09:08 PM
1998ram5.9's Avatar
1998ram5.9
well, if i drive it hard, it will not hessitate, but if i drive normal all week, the following week it will run like a mutt.
Old May 25, 2010 | 09:18 PM
aim4squirrels's Avatar
aim4squirrels
Is it a misfire? The sluggish condition you Describe sounds like Vac leak or timing chain wear, not a misfire.
Old May 25, 2010 | 09:28 PM
1998ram5.9's Avatar
1998ram5.9
well, wats a missfire like? all it does it like im letting of the throttle. Iv also noticed it spark knocks more when its doing that miss. When it does not miss all week, no spark knock at all.
Old May 26, 2010 | 08:16 AM
aim4squirrels
Spark knock would be more in Line with a misfire condition. When is the last time the cap, rotor, wires, and plugs were replaced?. If you use a cheaper set of wires, the spark can jump between wires and cause a misfire situation.
The coil output could be suspect as well.
Old May 26, 2010 | 08:30 AM
1998ram5.9's Avatar
1998ram5.9
I have never changed the coil, but i did a tune up starting a year and half ago. Did 8.2 taylor wires, ngk v power plugs, mopar perfomance dist. cap and rotor, is it possible that the sparkplugs are junk, from my plenum gasket going?
Old May 26, 2010 | 08:41 AM
95RAM360's Avatar
95RAM360
if the 5 and 3 spark wires touch it can cause misfires for they fire right after one another, and i believe its the same with 6 and 2 spark wires.
Old May 26, 2010 | 08:44 AM
1998ram5.9's Avatar
1998ram5.9
ok i will check that, i though it was 5 and 7 you had to be carefull about. Because of how close they are and they are right next to eachother in the fireing order
Old May 26, 2010 | 08:45 AM
1998ram5.9's Avatar
1998ram5.9
would a plugged cat cause spark knock?
