Latest upgrade Anti-wrap bar
Old May 19, 2010 | 12:55 AM
northernRAM's Avatar
northernRAM
Default Latest upgrade Anti-wrap bar
took a bit, 1 hiem joint, 3 poly suspension bushings, some flat plate and its done
[/IMG]
[/IMG]
[/IMG]
Old May 19, 2010 | 01:02 AM
97tn4x4's Avatar
97tn4x4
That looks awesome. How does it perform?
Old May 19, 2010 | 01:08 AM
northernRAM
only day plate it at the moment, so no tests have been done yet, but i got access to a fork lift at work to really test it to make sure it doesnt bind when fully arcticulated. Here is a full behind shot, i trianglated the shocks and dont worry bout the exhaust hanging from the string, still plumbing it in
[/IMG]
Old May 19, 2010 | 01:10 AM
99dodge318's Avatar
99dodge318
that is f#?*! sweet!! can you post some diminsions and angles. i want one on each side!
Old May 19, 2010 | 01:16 AM
northernRAM
the biggest problem you will run into is finding room on the diff and dealing with the fuel tank on the driver side frame rail, the passenger side is the way to go seeing how the front swing shackle can be tucked up nice and high in the frame rail
Old May 19, 2010 | 02:55 AM
97tn4x4's Avatar
97tn4x4
Is there much articulation advantage to the shocks being triangulated? If it works out good how bout specs, pipe diameter and length, bushing size and so on. How much block do you have in the back?
Old May 19, 2010 | 03:09 AM
dodge15004x45.9's Avatar
dodge15004x45.9
Screw all of that get some dam leafs not blocks. Take that 8" of block out of there!
Old May 20, 2010 | 12:32 AM
northernRAM
The first big block is the factory one and the other 2-2.5" block came with my lift kit. One advantage of triangulated shocks is less dragging resistance on the bottom of the diff while plowing through the mud and yes those blocks are ****! Next project is gonna be a shackle flip on the rear and ripping the leaf pack down to a 3 leaf pack. Just need a bit of time, have had my fill on fabing stuff for a while, need to beat on the truck now
Old May 20, 2010 | 01:43 AM
dodge15004x45.9
More leafs. That is way to much block!!
Old May 21, 2010 | 12:32 PM
northernRAM
shackle flip means getting rid of the blocks
