suspension lift
Old May 22, 2010 | 04:50 PM
dodgeguy450's Avatar
dodgeguy450
Default suspension lift
hey everyone,
ive been looking into a 5in. suspension lift for my 97 dodge ram 2500. its a 5.9 liter, auto tran, regular cab 8ft bed truck. its also the 8,800 gvrw. ive been looking for about a week for a kit but i cant find one thats clear cut for my truck. im sure yall get this a lot so bear with me. thanks.
Old May 22, 2010 | 05:55 PM
lastrights's Avatar
lastrights
dont you have to get a bigger driveshaft for 5 or higher ?
Old May 22, 2010 | 07:44 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Index ring. Not nessary but its something to think about. It "clocks" The t-case so the front drive shaft wont bind while flexing.
If you are just doing this for looks you don't need it. But if you intend to wheel this truck its something to look at.
Old May 22, 2010 | 08:47 PM
5 inch front springs.
4 inch rear springs.
Keep in mind, these are JUST the springs, and there are more parts required. If you select an individual part, it will show what else is required on the right. Not going to be an inexpensive undertaking.
Note: Rears are only 4 inch, which will also effectively level your truck when it is UNloaded.
Old May 22, 2010 | 08:57 PM
dodge15004x45.9
Better off buying a kit rather than pice it together. 9 times out of 10 the kit will be cheaper.
http://www.topguncustomz.com/Store/products.php?S_ID=56
They will work with on prices just give them a call nice people down there.
Old May 22, 2010 | 09:04 PM
Big time.
Old May 22, 2010 | 09:24 PM
dodge15004x45.9
That is where I got my 3" lift from. I'm sure you can talk them down to 700 pretty easy. My 3" was 485 with a few upgrades and other little things.
Old May 23, 2010 | 02:34 AM
dodgeguy450
i can talk them down to 700 possibly? which kit are you referring to? the top gunz customs one or another one?
Old May 23, 2010 | 12:23 PM
jackdup ram's Avatar
jackdup ram
Not sure but I do not believe so, just set your pinion angle correctly, I have a 5.5" lift with a standard drive shaft.
Shawn.
Old May 23, 2010 | 12:33 PM
dodge15004x45.9
The top gunz brand. ITs all rough country ****. Its there coils and the rear add a leaf.
I really think you can they wanted 420 for my lift and I got them down to 377. SO as you can see there is some room in there. I would give is a shot rather than just paying full price.
