Leveling kits for a 2wd
Old May 23, 2010 | 12:50 PM
95 Jamin Ram's Avatar
95 Jamin Ram
Default Leveling kits for a 2wd
Im looking for leveling kit for a 2wd 1500. Foud these cheap on craigslist http://southjersey.craigslist.org/pts/1749985656.html would 2.5 be to much in the front?
Old May 23, 2010 | 01:50 PM
95 Jamin Ram
nvm those ones are for a 4wd. What about these pnes http://cgi.ebay.com/ebaymotors/1-94-...Q5fAccessories
Old May 23, 2010 | 02:08 PM
mr freeze's Avatar
mr freeze
You could always just get some lowering shackles for the back and level it that way.
Old May 23, 2010 | 04:09 PM
EndIsNear's Avatar
EndIsNear
Or if you wanna raise it to level it go to www.summitracing.com and look up Daystar spring spacers. You can go with a 1" lift, 1.5" lift, 2" lift, and 2.5" of lift. But the 2.5" requires new longer shocks. Easy to install. I did the 1.5" on mine.
Old May 23, 2010 | 05:57 PM
redheadhunter21's Avatar
redheadhunter21
If you want it level dont go with the 2.5 it will leave the back lower
Old May 23, 2010 | 06:40 PM
xjarhead69's Avatar
xjarhead69
I replaced everything on the front of my truck last July and had it aligned.
Did you have to get an alignment done after you install the 1.5 Kit?
Thanks.
Dave
Old May 23, 2010 | 07:08 PM
redheadhunter21
Dont know about the 1.5 but for sure on the 2.5
Old May 23, 2010 | 10:29 PM
95 Jamin Ram
ill have to measure the correct size i need but are those polyurethane spacers any good?
Old May 24, 2010 | 04:59 PM
dodgeram07's Avatar
dodgeram07
this is what i got..........40bucks and free shiping
http://www.suspensionconnection.com/...C09103D16.html
before
after
it's only a 1.5in,,,and stock shock rides the same to me
Old May 24, 2010 | 07:08 PM
EndIsNear's Avatar
EndIsNear
Thanks.
Dave
Yes I had to get an alignment done. Wasn't bad, but I also got my new tires and I didn't want them wearing out so soon. Either way, be it 1.5" or 2.5", your steering geometry is changed and an alignment is needed. Your toe alignment may not be off at all (mine was) but your camber surely will be and should be corrected.
