"Dodge Lean" pic
Old Jul 24, 2010 | 02:49 PM
  #21
aftermarket's Avatar
aftermarket
Mine sags on the drivers side too. Can't tell if it's the spring at the front causing it or the rear leaf spring doing that.
I don't have access to the LMC pricing, what is that going to cost to replace your leaf springs?
Old Jul 24, 2010 | 11:59 PM
  #22
2k10HemiRam's Avatar
2k10HemiRam
I'm finally joining the "Dodge Lean" group. Mines not that bad right now, takes people a little bit to notice it but I guess since it's my truck, I noticed it immediately. It'll be awhile before I get it fixed though since it isn't that bad, the driver side is maybe .5" lower then the pass. My top priority right now is my transmission, saving up to buy a viper tranny.
Old Jul 25, 2010 | 12:27 AM
  #23
jasonw's Avatar
jasonw
Site Moderator
Mine still has me bugged slightly... the rear is exactly the same on both sides, but in the front, the driver's side sags about 0.5 inches or a little more. I know that when I get in it, my extra 230 lbs of weight drops it down even a little more. That is the coil I had installed brand new last year, so I know the coils are fine.
I bought a 1" lift kit (spacers) for the coils. I am going to install one on only the driver's side this weekend (depending on when my in-laws leave) or next, as long as I can rent/find some coil spring compressors.
Old Jul 25, 2010 | 03:18 AM
  #24
FarmBoy428's Avatar
FarmBoy428
Yeah, if your going to replace the leafs, just have all four done even the shocks, coils etc... just knock em all outa the way so you dont run into any more trouble down the road...
Old Jul 25, 2010 | 04:30 AM
  #25
2k10HemiRam
Yea when I fix mine it'll actually be when I lift my truck 3" so everything is going to be replaced and I'll have a fresh new suspension to work with.
Old Jul 25, 2010 | 01:15 PM
  #26
greenmachine's Avatar
greenmachine
If you look closely you can clearly see that the truck is fine the house is not level.
Old Jul 25, 2010 | 02:46 PM
  #27
2k10HemiRam
Lol...this picture was taken before it started leaning, I think it's almost 3 months old. My truck just started leaning maybe a month ago.
Old Aug 14, 2010 | 12:09 PM
  #28
gipperkid's Avatar
gipperkid
I had a fix to the problem. I took the overload (bottom) spring from another leaf pack. I then cut the center out and used as a 1 inch lift block. Problem solved.
Old Aug 14, 2010 | 06:21 PM
  #29
95RAM360's Avatar
95RAM360
mine leans as well...but my driver shackle snapped and sent leaf spring into bed...after i fixed it, ive had the sag...so i think thats what caused my problem...Upgrade to 3/4 ton springs
