Axle swap
Old May 24, 2010 | 05:42 PM
riggin99's Avatar
riggin99
Question Axle swap
im putting a dana 70 out of a 96 ram 2500 into my 99 1500, would i have to get the driveshaft shortined i mean i can force it to fit but i am just uneased at doin that cause the shaft wont have any play in it...and the Ujoint is just swimmin in the yoke...i had the idea of switchin the yokes between the chrysler 9.25 inch axle and the dana 70 but since they are different splines thats a no go so i have no idea what to do...well i have ideas just lookin for some opinions or see if anyone else has done this
Old May 24, 2010 | 09:46 PM
Kraiger's Avatar
Kraiger
If there is a spicer dealer in your town then they can hook you up with a combo U-joint that will be the sizes you need. The drive shaft i would have shortend. You want to have a little bit of slip in the shaft. Also autozone or oriellys auto parts can help you out on the U-joint. You just need to take them the shaft and yoke and they can find on in the catalog. I did this for a while untill i just got a new driveshaft made.
Old May 24, 2010 | 11:59 PM
KY BIGRAM's Avatar
KY BIGRAM
Lift it a little and it will work out for you. I have a D70 rear and a D60 front in my 1500, you can see pics on the "Got Flex" thread. Prolly not wantong the lift I have but it will stretch it out some.
Old May 25, 2010 | 12:59 AM
riggin99's Avatar
riggin99
No i havent seen a spicer dealer around, i went to oriellys and the kid there was kinda of umm a ruh-tard he didnt know what i was talkin about asked what a ujoint was...another employee gave me a ujoint and said it would work but ya it was way too small...i was dreading having the driveshaft shortend i think ill just have one made cause i already have a 5inch skyjacker lift kit on it dont really wanna go any higher than that...thanks for the help
Old May 25, 2010 | 05:02 AM
Kraiger's Avatar
Kraiger
If you have one made then just tell the guy making them what the set up is and he can put the right end on. Plus if they make drive shafts then the probly have the right u joints to. haha. If your from Cali. a good drive shaft guy out there is High Angle Driveline. I have done business with them and so has friends on mine and they make great products.
