U joint and ball joint replacement
Old May 30, 2010 | 10:22 AM
  #21
tuski's Avatar
tuski
Originally Posted by dhvaughan
welcome to dodge ownership...
let me look into your future - i see you learning new things. i see you buying new tools. i see you spending lots of money. i see you learning all about....
plenum.
timing chain.
drive shaft u-joints.
OBD codes
ball joints
track bar
steering box
bearings
radio and speakers
cracked dash
heater core.
i would type more, but i have to go work on my truck. LOL
: ( aww. Hopefully not all with in 3 weeks. LOL It's nice to drive it again without anything being wrong (except leaky water pump, which i need to attend to).
Thanks for all the help guys.
Old May 30, 2010 | 03:10 PM
  #22
Sheriff420's Avatar
Sheriff420
plenum.
timing chain.
OBD codes
ball joints
track bar
steering box
bearings
radio and speakers
cracked dash
heater core.
I highlighted the other two items you should attend to while doing the water pump.
Old May 30, 2010 | 04:09 PM
  #23
truegent81's Avatar
truegent81
where do you recommend getting timing chain from? mopar? hughes? cloyes?
what about the water pump? im a little nervous about the timing chain but water pump shouldnt be too bad
also had my ujoints replaced last year at a napa car center. they stated that ball joints will need to be replaced soon. i lifted truck up and moved the tire looking for any movement and there wasnt any. so my question is, did i get lucky? are the ujoints a PIA to replace when compared to the ball joints? i've also heard about the brand MOOG for those. are they better than MOPAR or just a better price but similar quality?
sorry for jacking thread, just curious and trying to learn as much as i can.thx
Old May 30, 2010 | 08:34 PM
  #24
Sheriff420's Avatar
Sheriff420
Moog for suspension components. Mopar performance (from summitracing) or Cloyes for the timing chain/gears, double roller is preferred on the forum. Water pump brand doesn't really matter I don't think.
U-joints are easy, especially on a southern truck.
Old May 30, 2010 | 09:27 PM
  #25
tuski's Avatar
tuski
Hmmm, i never heard of a plenum (besides on this forum) nor do i know what it does, i've heard of the timing chain, but i have no idea of where the plenum is located.
I might have to hold off for them until i can save up some money. Being a college student, taking summer classes, and working part time doesn't leaving me with much cash leftover.
Old May 30, 2010 | 09:31 PM
  #26
Sheriff420's Avatar
Sheriff420
The plenum is the gasket between the lifter valley and the intake manifold, it is held onto the bottom of the intake manifold by the plenum pan.
I hadn't heard of it before joining this forum either. I actually changed my plenum gasket on my camaro and didn't know what it was, I thought it was just the intake manifold gasket.
