96 1500 A/C Help
Old May 26, 2010 | 07:11 PM
jpsycoboy5's Avatar
jpsycoboy5
Default 96 1500 A/C Help
ok i checked the freon said low i added freon i think its the compressor cycles on for 5 seconds then turns off when it cycles on the freon gauge drops to low i recorded a video of it so you all know what i mean. i dont want to have to take this to get fixed but its in the 90s and my ac doesnt work and im pretty sure it hasnt worked in the year ive had it please help let me know if theres any test i can do to know what is bad thanks guys
http://www.youtube.com/watch?v=i9Cfie5xehk
Old May 26, 2010 | 10:13 PM
Still low on charge. Blast some more in there.
Old May 26, 2010 | 10:28 PM
dhvaughan's Avatar
dhvaughan
how much did you add already? it probably takes 1-2 pounds from dead empty.
i just overcharged the crap out of mine and had to vent a bunch back out.
Old May 26, 2010 | 11:57 PM
truegent81's Avatar
truegent81
yeah i believe with the compressor cycling like that your bone dry. go ahead and add more, system holds 32oz
Old May 27, 2010 | 10:06 AM
jpsycoboy5's Avatar
jpsycoboy5
So I'm supposed to go to the blue with the cimpresor cycling not by what it says. When ir isn't
Old May 27, 2010 | 10:40 AM
jpsycoboy5's Avatar
jpsycoboy5
Ok so I added freon it's just in yellow before red the compressor still cycles and still drops into the green low psi
Old May 27, 2010 | 10:45 AM
Post another video. The compressor is supposed to cycle, it shouldn't run constantly.
Is your A/C blowing nice cold air?
Old May 27, 2010 | 04:08 PM
jpsycoboy5's Avatar
jpsycoboy5
Warm air is the only thing coming out not even a hint of cold
Old May 27, 2010 | 04:17 PM
I think you have more problems than just being low on charge.
