Temp sending unit
Old May 27, 2010 | 11:30 PM
dodgeram07's Avatar
dodgeram07
Question Temp sending unit
Help point me in the right way i thought I got the correct sending unit but went I put it in the front serto port it looks to be to long it will not thread in and it's I 1/8 in unit..... Any help would be nice
thanks
Old May 27, 2010 | 11:43 PM
Cheat's Avatar
Cheat
http://www.glowshiftdirect.com/1-8-n...g-adapter.aspx
Maybe?
Old May 28, 2010 | 12:33 AM
J415's Avatar
J415
Front servo really isn't where you should put it. You should put it in the feed line (out going) of the trans.
http://www.dieseltrans.com/phpBB/viewtopic.php?t=558
Old May 28, 2010 | 01:37 AM
dodge15004x45.9's Avatar
dodge15004x45.9
I see feet!
Old May 28, 2010 | 07:58 AM
EricCartman's Avatar
EricCartman
This is what I was planning on using when I do my temperature gauge install:
http://www.dieselmanor.com/dm_products/DM-TRS.asp
It say it reads about 5 degrees cooler than when the sensor is directly in the fluid (at 200F). But, you don't have to cut any of your lines to make it work.
Cartman
Old Jun 9, 2010 | 01:03 AM
dodgeram07's Avatar
dodgeram07
Bump
Old Jun 9, 2010 | 01:08 AM
RamSport97's Avatar
RamSport97
Originally Posted by dodgeram07
Bump
What gauge did you go with? I know Silver Dodge and CSX Fan got the Autometer trans temp gauge and the sender unit that came with it fit perfect in the servo.
Old Jun 9, 2010 | 01:16 AM
dodgeram07's Avatar
dodgeram07
Well that's the thing I have a few gauges sitting back form diff projects.... The one I tryed is a sunpro temp gauge for oil or coolet...... So maybe the sending units for shorter? Than all I would need is a diff sender,, but when looking on jegs they look the same
Old Jun 9, 2010 | 10:33 PM
MrRuckuss's Avatar
MrRuckuss
i used the back servo port works just fine.
Old Jun 9, 2010 | 11:34 PM
dodgeram07's Avatar
dodgeram07
did your sending unit look to be just as long as the one i have?
