Exhaust size question (electric cutout)
Old May 29, 2010 | 03:11 AM
bobboraze's Avatar
bobboraze
Default Exhaust size question (electric cutout)
I've searched through a bunch of threads, yet I continue to see back and forth between 2.25" and 2.5"...
Basically I'm picking up an electric cutout to throw on my stock exhaust and they come in 2.25" 2.5" and 3". (though they seem to be flared at the ends to that size?)
Anyway, any help would be greatly appreciated!
2.5" - http://cgi.ebay.com/ebaymotors/Badla...Q5fAccessories
2.25" - http://cgi.ebay.com/ebaymotors/Badla...Q5fAccessories
Old May 29, 2010 | 09:17 AM
Crawl under your truck and measure the pipe that is under there now?
Old May 29, 2010 | 05:18 PM
bobboraze's Avatar
bobboraze
Well yes I suppose I could take the circumference and then find the diameter... though as .25" isn't that great of a value I figured it'd be easier and safer to ask specifically what size it is. (assuming someone has to definitely know)
Old May 29, 2010 | 05:50 PM
lastrights's Avatar
lastrights
you want the DMH 3 inch si/so
Old May 29, 2010 | 05:59 PM
Sheriff420's Avatar
Sheriff420
The circumference will be 7.853 if the diameter is 2.5"
The circumference will be 7.068 if the diameter is 2.25"
I cheated, instead of thinking back to high school math I used an online conversion tool
http://www.onlineconversion.com/circlesolve.htm
So wrap a string around it and measure the string. If it is barely over 7" then it's a 2.25" pipe. If the string is almost 8" then it's a 2.5" pipe.
Old May 29, 2010 | 06:54 PM
jasonw's Avatar
jasonw
Site Moderator
I like how Sheriff did that. I recommend following his advice.
If its still factory, it should be 2.5" after the cat all the way through, IIRC.
Old May 29, 2010 | 06:58 PM
redheadhunter21's Avatar
redheadhunter21
Different years have different size pipes the earlier years have a 2.25 pipe and in later years I think either 00 or 01 they went to a 3 inch
and i have heard that some people had 2.5 pipes, so save yourself the hassle and just measure it
Old May 30, 2010 | 04:01 PM
bobboraze's Avatar
bobboraze
Yup simple enough, measured around 7" (bend before the cat). 1999 4x4 Ram Sport.
Though the pipe section is only around 7.5" long, not sure if the cutout will fit anyway...
The section between the cat/muffler would be absolutely perfect, yet there's an o2 sensor mid-way...
Old May 30, 2010 | 04:20 PM
Ugly1's Avatar
Ugly1
You should be able to weld an O2 bung anywhere after the y pipe and before the cutout.
Old May 30, 2010 | 04:24 PM
lastrights's Avatar
lastrights
ya i had a 3inch si/so after my cat before it was fine
