Im sick of hearing the rattle.
Old May 30, 2010 | 11:28 AM
95 Jamin Ram's Avatar
95 Jamin Ram
Default Im sick of hearing the rattle.
My catalytic converter has been busted for about 2 years now its starting to get worse my only problem is i dont have a welder. What kind of epoxy or JB Weld can i use this? Also my brake pedal feels loose like when a bump is rattles anything i can do to tighten this up?
Old May 30, 2010 | 11:36 AM
Maxx_Magnum's Avatar
Maxx_Magnum
see if you can get the pipe off behind the cat, and use something long to break up the contents enough to get out.... revvin on it will help blow it out too... This way you wouldn't need a welder
Old May 30, 2010 | 11:37 AM
95 Jamin Ram
Is there a screen in there if i went through the back?
Old May 30, 2010 | 02:51 PM
Maxx_Magnum
no I wouldn't think so, just the honeycomb stuff. I've never done one of these cats (mine was gutted when I got it, and I can see where they cut the side out of it then welded it back up) but I haven't seen a screen on any other ones I've done, mostly chevs when I was younger...
Old May 30, 2010 | 03:00 PM
GeorgiaDodge's Avatar
GeorgiaDodge
make sure you take the 02 sensors out before you bust the guts out of it
Old May 30, 2010 | 03:08 PM
Sheriff420's Avatar
Sheriff420
If you're going to gut it then you should go to the parts store and get a female to female 2.5" ID sleeve and two clamps so you can put the pipe back together after gutting, and you need to take the 02 sensors out of the pipe so you don't smash them up.
Your other option is to get a Magnaflow from summit and have a muffler shop weld it on, it should cost between 30 and 60$ to have the cat put on at a shop.
Old May 30, 2010 | 04:01 PM
Ram_Me's Avatar
Ram_Me
Will those high flow cats still pass emissions? I can't afford to buy something that I'd have to take off because it "kills the environment."
Old May 30, 2010 | 04:15 PM
truegent81's Avatar
truegent81
hey hey hey. just got my magnaflow cat yesterday. i ordered it thursday at 10pm and it was at my door in one day! got to love living in GA since it comes from McDonugh,GA. from my understading the cat will pass emissions. on the summit website it states it is emission legal in 49 states (not Cali. but what do you expect).
im having a muffler shop weld mine in on tuesday or ASAP afer the holiday. shouldn't be expensive to do at all. they just have to remove old cat and weld in the hi flow one. should take about 20-30mins. IMO i would go with the hi flow cat bc it ain't jerry rigged and half ***, its more professional/clean. the pipes leading up to cat are 3" but after the cat is go to 2.5" and then after the tire finishes at 3". jasonw explained it well. the muffler shop just puts a reducer on after the cat.
jasonw helped me out on this issue. i ordered mine from summitracing and the cat+SH=$83.
Old May 30, 2010 | 11:10 PM
J McWillis's Avatar
J McWillis
I've had a magnaflow cat for a few months, and passed my inspection just last week. I'm in TX, dunno if there's a big difference in the emissions requirements. It ran me about 125 out the door and about 25 bucks to get put on. Definitely worth it IMO.
Old May 31, 2010 | 12:17 AM
truegent81's Avatar
truegent81
with the magnalow can you tell any difference in performance? sound? i already have a flowmaster 40s but i didnt know if having the magnaflow cat would make it a little louder (since letting more air rush through the pipes). i like the 40s tone so im not looking for loudness, just the solution to a clogged cat down the road
