Something is wrong with my truck. I get bad gas mileage
Old Jun 17, 2012 | 04:12 PM
  #81
stewie01's Avatar
stewie01
Short beds should be 26G and the long beds are what, 35G?
Old Jun 18, 2012 | 07:12 AM
  #82
bent-fender's Avatar
bent-fender
Yeah, pno thanks Ill keep my info and just figure out the issue my self.
Old Jun 18, 2012 | 08:54 AM
  #83
Augiedoggy's Avatar
Augiedoggy
Originally Posted by bent-fender
Yes but when the needle in my truck is on the red line I have 10-15 miles before Im dry. So when I figured the 280 to a tank I figured in the last 15miles for the gallon that was left. I put 23.8 gallons in the truck when I ran it that low. Now assuming I have a 25 gallaon tank that left me with 1.2 gallons.
You guys see what Im trying to tell yall yet?
yeah...your telling us your doing a lot of assuming.... your cant use the gauge... its not accurate enough period...
Old Jun 18, 2012 | 09:00 AM
  #84
Augiedoggy's Avatar
Augiedoggy
You kinda mis understood me I am measuring by a full tank so full it spit up. I mentioned the half tank to let you know that it drops faster than running on a fuller tank, why I do not know it just does. Right now I am at 262.5 and have a 1/8th of a tank left.
An what is a death flash? An how do I remove it?
The reason the half tank drops faster than a full tank if because the gauge does NOT accurately measure the fuel level in relationship to whats actually in the tank....its to be used as a rough estimate and is useless for much else...
Old Jun 18, 2012 | 12:03 PM
  #85
MoparMan1991's Avatar
MoparMan1991
Man, this thread has become more of a nuisance than anything else.
Just face the facts, you have a truck. Your MPG will be bad. If you want better i'm sure someone still has a Neon for sale on your local craigslist.
Old Jun 18, 2012 | 02:49 PM
  #86
bent-fender
No sht captain obvious. All I wanted to know is why It dropped after I did a tune up and added new tires out back.
Old Jun 18, 2012 | 03:53 PM
  #87
jeff351's Avatar
jeff351
I'm getting 11mpg in my truck, and it has the 1ton axle swap, 37" tires ..as well as a stock 5.2 and 4wd. I'm thinking thats pretty good!
Old Jun 19, 2012 | 04:32 AM
  #88
MoparMan1991
You probably forgot to top off your blinker fluid.
Old Jun 19, 2012 | 07:30 AM
  #89
tbone360's Avatar
tbone360
This just keeps getting better and better lmao.
Old Jun 19, 2012 | 10:45 AM
  #90
QuadCabLuv's Avatar
QuadCabLuv
Get you a pair of truck nutz. They lower the aerodynamic drag on the interstate.
