Something is wrong with my truck. I get bad gas mileage
Old Jun 15, 2012 | 08:09 PM
  #71
QuadCabLuv's Avatar
QuadCabLuv
In my last ram 1500 2wd qc with the 5.2 i would get right around 380 out of a full tank. God i wish i still had that truck. My 2500 gets about 290 to a full tank
Old Jun 15, 2012 | 11:52 PM
  #72
bent-fender's Avatar
bent-fender
i doubt in that 280 miles that you burnt through all your gas. i think you just need to keep better track of everything.
I dont think so. I fill it full lock the cap,reset trip to zero, and ran it down to the red line unlocked cap and refueled 23gallons. I noticed today that the truck seem'd sluggish.
stewie01 You mean 4x2. 2x4 is a piece of wood.
yes thats what I meant 4x2 its 2wd truck 1500
Old Jun 16, 2012 | 12:07 AM
  #73
gdstock's Avatar
gdstock
I don't lnow how one can accurately measure milage by how many miles per tank...unless you run it dry each time. Accuracy of gauge near the top or near the bottom of the range is way off. Actual miles divided my gallons to fill is the only way to measure.....
Old Jun 16, 2012 | 11:03 AM
  #74
If you reset trip at fill up, drive until you want gas again, fill it up again, you know the number of miles, and how many gallons you used. There is gonna be some margin of error, simply because on different days, the pump will kick off at different points. (even different pumps will kick off at different points....) but, close enough for government work.
Old Jun 16, 2012 | 01:59 PM
  #75
crazzywolfie's Avatar
crazzywolfie
that is why i usually use the same gas pump at the same gas station. i try to almost empty the tank as much as possible.
Old Jun 16, 2012 | 03:25 PM
  #76
bent-fender
ok so if doing the same way I have done it for 10 years is wrong then what do you guys suggest. Ill need an answer by tomorrow as I will fill up again tomorrow on the way to work.
Old Jun 16, 2012 | 04:38 PM
  #77
Fill tank, reset trip odo, drive..... fill tank, make note of gallons put in, and miles traveled, do the math.
On my truck, when the 'low fuel' light comes on, there is still six gallons of gas in my 26 gallon tank.....
Old Jun 16, 2012 | 04:39 PM
  #78
stewie01's Avatar
stewie01
Mine too, the Caravan is the same way also....
Old Jun 17, 2012 | 03:11 PM
  #79
bent-fender
Yes but when the needle in my truck is on the red line I have 10-15 miles before Im dry. So when I figured the 280 to a tank I figured in the last 15miles for the gallon that was left. I put 23.8 gallons in the truck when I ran it that low. Now assuming I have a 25 gallaon tank that left me with 1.2 gallons.
You guys see what Im trying to tell yall yet?
Old Jun 17, 2012 | 03:42 PM
  #80
zman17's Avatar
zman17
Retired Moderator - RIP
No Dodge Ram has a 25 gallon tank. So all your figuring is wrong. I suggest you get one of these. http://www.dodge.com/wccsapp/univers...ull&category=U
