Something is wrong with my truck. I get bad gas mileage
Old Jun 19, 2012 | 11:09 AM
  #91
I don't think thats actually the case. I believe that was a misperception..... I think that actual cause of higher gas mileage with truck nuts is due to the folks behind you speeding up, to check and see if you REALLY DID hang those things off your hitch..... causing a pressure wave to help push your truck along.
Works best on crowded freeways.
Old Jun 19, 2012 | 04:52 PM
  #92
bent-fender's Avatar
bent-fender
Well this was a waste of time.
Old Jun 19, 2012 | 06:14 PM
  #93
Johnn123's Avatar
Johnn123
Originally Posted by bent-fender
No sht captain obvious. All I wanted to know is why It dropped after I did a tune up and added new tires out back.
Bigger size then before? Switched from a street to an all terrain or mud tire? That would be why.
Old Jun 19, 2012 | 09:46 PM
  #94
Augiedoggy's Avatar
Augiedoggy
good point on the tread design... a member here stated a while back he lost 3mpg just by going to an aggressive tread design...
Old Jun 20, 2012 | 12:00 AM
  #95
QuadCabLuv's Avatar
QuadCabLuv
This is true i lost a couple when i switch to hankook dynapros atm
Old Jun 20, 2012 | 02:08 PM
  #96
Johnn123's Avatar
Johnn123
I gained approx 2mpg when I switched from my BFG All Terrains to my Moto Master street tires. Same tire size and everything just different tread pattern. Less resistance i guess.
