Coil spacers
Old May 31, 2010 | 10:50 PM
barrypotts1b's Avatar
barrypotts1b
Default Coil spacers
Is there any negatives to coil spacers. For example on a leveling kit
Old Jun 1, 2010 | 12:25 AM
J McWillis's Avatar
J McWillis
+1. Been looking at spacers also. Can't decide on spacers or a bit longer coil.
Old Jun 1, 2010 | 12:30 AM
dodgeram07's Avatar
dodgeram07
i did a 1.5in on my truck,,,and all is well
Old Jun 1, 2010 | 12:32 AM
GeorgiaDodge's Avatar
GeorgiaDodge
i would like a 1.5 leveling kit, how bad are they to install?
Old Jun 1, 2010 | 12:46 AM
dodgeram07's Avatar
dodgeram07
not bad at all about 3-4 job and take because i had a hell of a time getting the bolt on the shock off heat didnt help...thank salty ohio
before
after
Old Jun 1, 2010 | 12:59 AM
J McWillis's Avatar
J McWillis
dodgeram07, every time i see your truck i can't help but think of how much it reminds me of mine.. except with less scratches and more clear coat.. and level
Old Jun 1, 2010 | 01:02 AM
TheBigRedOne's Avatar
TheBigRedOne
They will eliminate nearly all of your downtravel. Bad juju when you only have around 4 inches to begin with. Found this out the hard way with a customers F150. One of his ball joints blew up when it became the limiting point of the suspension at droop. We'll never install one again.
Old Jun 1, 2010 | 07:28 AM
olyelr's Avatar
olyelr
An IFS leveling kit is quite a bit different than one for a solid axle. But then again, I have no clue if the OP is questioning a leveling kit for a 2WD dodge or 4WD dodge... quite a bit of difference between the two.
Old Jun 1, 2010 | 08:48 AM
barrypotts1b
the spacers are for a 4 wheel drive 1998 1500
Old Jun 1, 2010 | 11:18 AM
bigtman07's Avatar
bigtman07
I just put a 2 1/2inch on my truck last week. So far no ill affects. Depending on the size of leveling kit you may need a spring or struck compressor. I had to use one cause I couldn't get the suspension to release enough. Spent about 5 hours total that day on the spacers. Wasn't hard just time consuming.
