Ignition hesitation?
Old Jun 2, 2010 | 10:28 PM
J McWillis's Avatar
J McWillis
Default Ignition hesitation?
Hey guys. Within about the past week I've begun to notice that when I hop in the truck and go to start it, it seems to hesitate for a second or two before cranking up. Cranks fine, runs like normal. It's just after I turn the key it waits a full second or so before turning the starter. No odd noises or anything. Anyone experienced this before? Wondering if the switch/solenoid is getting worn out. TIA.
Old Jun 2, 2010 | 10:44 PM
chogg's Avatar
chogg
Check the battery cables and all the connections at the starter first then check the starter. it was a bad battery cable on mine.
Old Jun 2, 2010 | 11:45 PM
J McWillis's Avatar
J McWillis
Will do. Probably time for some new cables anyways. Didn't look as well as I'd hoped when I did the battery not long ago.
Old Jun 3, 2010 | 09:17 AM
UnregisteredUser's Avatar
UnregisteredUser
Also check the starting relay in the power distribution center. It might be tired.
Old Jun 3, 2010 | 03:29 PM
J McWillis's Avatar
J McWillis
I'll add that to the checklist. Thanks for the help guys.
Old Jun 3, 2010 | 03:37 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
How does a relay "get tired"? Can a visual inspection determine tiredness?
Old Jun 3, 2010 | 03:58 PM
UnregisteredUser
What happens is that the core of a DC relay eventually gets magnetized so it is not so greatly affected by the magnetic field created by the relay coil. The symptoms are reduced contact pressure and slow closure. Later, the contacts just won't close at all because the core can't overcome the contact spring pressure. Depending upon the relay style, you may or may not be able to detect a magnetized core by measuring the coil current. In those relays that don't have (current) limiting resistors or solid state drivers in them, coil current will go up in proportion to the magnetization of the coil. To test in this way you need to know what a normal relay's coil current should be.
The easy way to spot a tired relay whose case is opaque is to listen while energizing it -- there will be a relatively long latent period between application of coil voltage and the click of the contacts closing. If the relay is too quiet to be heard over ambient noise, you'll have to test it electrically. A multimeter or test light will work just fine in an automotive application. The tricky part is finding the right wire to probe.
All that said, the easy way to figure it out is to swap in another (known good) like relay from a non-critical circuit and see if the problem clears up. If it does, you need a new relay.
Old Jun 3, 2010 | 04:06 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Awesome explanation. I done learnt something today.
Old Jun 3, 2010 | 04:24 PM
J McWillis's Avatar
J McWillis
Well, I just went out and swapped the relays. No change. It seems like the delay is somewhere between the relay and the starter. Relay clicks-1 to 2 second pause-Cranks. I'm starting to think the starter's just getting worn out due to a seemingly slow crank..
EDIT
Now it's only wanting to start every few tries. Nothing but a click otherwise. New starter and cables, here I come..
Old Jun 4, 2010 | 11:09 AM
ryan0714's Avatar
ryan0714
before u waste all ur money check the solenoid on the starter. u can take ur starter off and get it tested.
