97 2wd 2500 tire size
Old Jun 3, 2010 | 12:17 PM
locked up's Avatar
locked up
Default 97 2wd 2500 tire size
I currently have 245/75r16s (basically a 31") and they are worn out. I was wondering ... how large of a tire can I fit in there stock? 32"? larger?
What if I put a 2" leveling kit up front? Or are those spacer level kits frowned upon?
Old Jun 3, 2010 | 12:26 PM
dodgeram07's Avatar
dodgeram07
i got a level kit on mine
if you put the kit on you should beable to run a 285/75/16..33in
Old Jun 3, 2010 | 03:19 PM
locked up's Avatar
locked up
Did you put new shocks in?
Any issues with alignment or the handling?
Old Jun 3, 2010 | 03:56 PM
dodgeram07's Avatar
dodgeram07
well i put a 1.5 on and still have stock shocks..... i havent got a alignment yet,,, but it shouldnt be a problem
handling change a little up front due to the front being higher,,, i dont think i can turn right turns as fast because there is more front end push,,,,but its a truck not a vett
Old Jun 3, 2010 | 11:20 PM
redheadhunter21's Avatar
redheadhunter21
Being a 2500 I would say you would be ok with a 285/75/16 but it may depend on the tire you get, if you have some rub then a 1.5 spacer should solve that problem, On my 1500 with a 285/75/16 and the stock height I had some rub only on the plastic though
Old Jun 4, 2010 | 12:50 AM
95RAM360's Avatar
95RAM360
Thumbs down
agreed, since its a 2500, its sits probably about the same as a 1500 4x4, so id say you'd be good with either 265's or 285's
Old Jun 4, 2010 | 01:02 AM
southern13guy's Avatar
southern13guy
Did you put the 285's on your stock wheels that are in your pic? I called a tire place and they suggested to not go any bigger than 265 on the stock wheels...
Old Jun 4, 2010 | 01:05 AM
95RAM360's Avatar
95RAM360
you can have 285's on stock wheels...seen many with just that
Old Jun 5, 2010 | 08:01 AM
chogg's Avatar
chogg
im running 285/75/16 on my 2500 4x4 no problem at all and could prolly go bigger if I wanted. I don't have a lift that I know of it doesn't sit any higher than the other 2500 4x4's around town.
Old Jun 5, 2010 | 01:56 PM
redheadhunter21
No I got new rims need to clean my truck and take a new sig pic one of these days picked up another job so I havent really had the time I used too.
But yeah you should be ok with 285's and stock rims general rule is 4 inches and your ok with an extra .5
