timing chain set
Old Jun 4, 2010 | 12:12 PM
  #21
Originally Posted by truegent81
remove spark plugs? can you remove old spark plugs and then reinsert them? also do we wrap teflon tape around the threads of the spark plugs before we put them in?
Pulling the plugs makes it MUCH easier to turn the motor over.... you won't be fighting compression.
Yes, you can re-use spark plugs. If they don't look too bad, put 'em back in, if they look crappy, replace 'em.
Old Jun 4, 2010 | 12:17 PM
  #22
Fifthwheelin's Avatar
Fifthwheelin
Isnt it a little scary that your explaining that to the guy holding a chain fed weapon???
Just sayin.....
Old Jun 4, 2010 | 12:21 PM
  #23
Just sayin.....
Belt fed.
Don't give him any wrong info....... It isn't wise to **** off the man with the automatic weapon.
Old Jun 4, 2010 | 12:25 PM
  #24
Fifthwheelin
True gent, you can learn alot about your engines performance by checking the spark plugs, google reading spark plugs and you will find out quite a bit.
Always gap your plugs correctly and use antisieze on them when installing/reinstalling them to keep them from siezing in the head.
Old Jun 4, 2010 | 01:44 PM
  #25
truegent81's Avatar
truegent81
Just sayin.....
you know what? ive been in the army since i was 19. i could of cared less about knowing a damn thing about trucks when i was younger. today it is just more economical for me to work on my own, hence why i ask a lot of questions that need to be EXPLAINED. did you know a damn thing about trucks when you came into this world? **** if that is the case (sarcasm). i have NEVER done extensive work on any vehicles because i didnt know anything about them. i asked about teflon bc someone asked about that in a thread a while back.
should i belittle you for not knowing that the 249 is BELT fed instead of a CHAIN fed weapon? there are no dumb questions. the only dumb question there is, is the one that doesnt get asked...just saying
