Dissolving Locktite
#22
#23
Permatex® Medium Strength Threadlocker BLUE
OEM specified. All-purpose, medium strength threadlocker. Ideal for all nut and bolt applications 1/4" to 3/4" (6mm to 20mm). Eliminates need for stocking expensive lock nuts and lock washers. Locks and seals while preventing parts loosening due to vibration. Protects threads from corrosion. Removable with hand tools for easy disassembly.
Suggested Applications: Valve cover bolts, water pump bolts, oil pan bolts, drive shaft bolts, rocker arm adjustment nuts, carburetor studs
thats from the permatex site. aim just had a bad break (no pun intended) but i hope you got this taken care of with ease. you got a sitrep for us? aim you said you just tightened it down with a wrench and it still snapped. i wanted to know how many of yall torque every little bolt to specs? for those that don't, do you torque any or just tighten by hand til it is secured and tight?
#25
#26
#27
Head bolts, flywheel bolts, torque converter bolts all get the torque wrench. Everything else is torqued to german torqu specs guddentight
Blue loctite may be removable by hand if you put a dab on. If your like me, the bolt was wet on every thread, and requires heat.
yeah i guess it just depends on how much of the threadlocker you use. i noticed on the permatex packaging they only use the threadlocker on the bottom portion of the fastener which does make sense.
#30
not very often unless its something that i think really needs to be right....and once i grabbed my ft lb torqe wrench and snapped a bolt....the specs were in inch lbs....have checked a little better since then
