Stupid plenum...
Old Jul 31, 2010 | 04:07 PM
  #131
J415's Avatar
J415
Originally Posted by aim4squirrels
Hey,
That was a full-on double rainbow, all the way. Worth the 3 1/2 minutes.
It was ALMOST a triple rainbow!!! It made me want to cry!!! JK
Old Jul 31, 2010 | 05:29 PM
  #132
I got a best of about 18 mpg on my 2500 with mostly highway driving. (not freeway though, so, speeds around 60 or so.)
Old Jul 31, 2010 | 06:31 PM
  #133
offroadjosh's Avatar
offroadjosh
So should i not buy the plenum fix then? I need to replace my gasket but if the fix doesn't work then i guess its either airgap or the gasket and i cant afford the airgap
Old Jul 31, 2010 | 08:16 PM
  #134
UnregisteredUser's Avatar
UnregisteredUser
You can see doubles and triples pretty regularly on the Western Slope of the Colorado Rockies, and occasionally in the Yosemite Valley, without listening to some stoned fool crying like he was just crowned Miss America.
I wonder if I can beat my 3-1/2 minutes out of that guy. Vicariously, anyway -- I know folks out that way...
Old Jul 31, 2010 | 08:29 PM
  #135
Plenum fix does indeed work. Just take your time when assembling it. A LOT cheaper than a new manifold.
Old Aug 1, 2010 | 09:16 AM
  #136
Sheriff420's Avatar
Sheriff420
And put a friggin filter on your PCV valves hose so it won't make you wonder if the new gasket failed after a couple months. I still need to get one for mine. The PCV inlet on the manifold was saturated with oil when I took the manifold off the second time.
Old Aug 1, 2010 | 12:23 PM
  #137
aim4squirrels's Avatar
aim4squirrels
Perhaps a song will make you feel better:
http://www.youtube.com/watch?v=MX0D4...layer_embedded
Old Aug 1, 2010 | 12:48 PM
  #138
pcfixerpro's Avatar
pcfixerpro
What style filter would you recommend? clamp on like with fipk delete, or is there an inline that would still pull vac and keep keg clean. I pulled my plenum this weekend only to find the same thing you did. Believe it or not, at 120k, my plenum was still really good. Looks like those two upper bolts just started to leak. I didn't have ping, but I was using a quart over an oil change which prompted me to change the gasket.
Old Aug 1, 2010 | 12:53 PM
  #139
aim4squirrels
Looking at that pic leads me to believe you were indeed leaking.
There is oil between almost every one of the screw mounts on the sides of the intake manifold itself, some on the gasket that's still on the pan, and missing gasket in the back of the pan by where the distributor is.
Looks as if your bolts bottomed out on the original pan.
Old Aug 1, 2010 | 02:49 PM
  #140
pcfixerpro's Avatar
pcfixerpro
Wasn't quite sure. Whats wierd is where those oil stains are on the manifold... is where the gray marks are on the gasket. and it is like some sort of RTV. Didn't know that came like that stock...
