Stupid plenum...
Old Jun 8, 2010 | 01:35 PM
Sheriff420's Avatar
Sheriff420
Default Stupid plenum...
Well I put my modified throttle body on this morning because I made an adjustment on it that got rid of the high idle and saw something that I didn't like one bit.
When I pulled the throttle body off I decided to look into the intake to see if it was still clean since I replaced the plenum gasket with felpro and the pan with hughes. Well it wasn't.
A light film of oil was in there, so I assumed PCV right off the bat and when I looked at the PCV port I saw oil on it and figured that was where the oil came from. Then I looked at the back of the intake and saw a puddle that was too big for the little bit that might come through the PCV valve, ugh... stupid plenum.
I did decide on a solution though, and my wallet is feeling the sting. I ordered an airgap, so "yay" for the airgap, but "crap" for the stupid plenum gasket.
Why did they put a plenum pan on there in the first place? Why would anyone need access to the inside of the keg?
Old Jun 8, 2010 | 01:48 PM
dodgeram07's Avatar
dodgeram07
Because they are cheap a$$'s and it may have saved them a little money on each truck...... I'm kinda don't want to look down mine the day I got into it The other day and the power wasn't there like it was hope mine is not blow again
Old Jun 8, 2010 | 01:52 PM
dodgeram07's Avatar
dodgeram07
But Yay for the air gap..... I would like one but they don't have egr on them
Old Jun 8, 2010 | 01:54 PM
truegent81's Avatar
truegent81
well sorry to hear that **** happened to you again. any idea what might have caused this since i am ordering the hughes as well. ****ing corporations making cheap **** just to save THEM money and hurting customers in the end because we don't really have another option (besides more corporations).
Old Jun 8, 2010 | 02:13 PM
Sheriff420's Avatar
Sheriff420
Dunno what caused it, maybe the threads on the pan bolts still had a little oil in them and a bolt or two got a little loose. I did it by the book and torqued the pan a few times to make sure that the bolts were all at the right torque. Like I said though, it's a stupid design.
Mine has felt a little sackless for a while now and I assumed that it was from the bigger tires, but at the same time I couldn't understand it because they are the same size as the tires that were on it when I got the truck. Now I know it is from a vacuum leak.
Old Jun 8, 2010 | 02:18 PM
SnowFox's Avatar
SnowFox
yea that sucks.... post some pics of the air gap when u get it installed ^.^
if it works good for u then ill save a little more money up and just buy a intake instead of the plenum pan....
Old Jun 8, 2010 | 02:42 PM
calgaryman's Avatar
calgaryman
I'm interested to see if the bolts just came loose. I just experienced that yesterday when I opened up my plenum. I thought it might have been from the PO not torquing properly. But it looks like that might not be the case.
Did you use locktite on the bolts?
Old Jun 8, 2010 | 02:51 PM
Sheriff420's Avatar
Sheriff420
I'll have at least one picture when I get it done.
Everything I've read about the airgap says that it's awesome because you get more 2000-4500 rpm power and better mileage.
Yep, threadlocker blue on the pan bolts.
lastrights's Avatar
lastrights
yay im excited
Old Jun 8, 2010 | 02:57 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Sheriff,
You better report back with your results of the Airgap. I'm seriously leaning that way for next Spring's project (among a few others planned for my Dodge).
