Stupid plenum...
Old Jun 13, 2010 | 08:00 PM
  #71
Maxx_Magnum's Avatar
Maxx_Magnum
Kinda sounds like just one of them deals, where something fails for no good reason.... I haven't heard of anyone elses hughes kit leaking again.... That airgap is sexay lookin though
Old Jun 13, 2010 | 10:38 PM
  #72
Sheriff420's Avatar
Sheriff420
I put the IAT in the air hat today and realized that my 14x3 is too tall, so I need to go get a 14x2 or 2.25. I'll have to run the paper filter until I get that. (Anyone need a 14x3 K&N?)
I filled the radiator and was ready to crank it up and I heard a gushing noise when turning the truck on.
I planned on turning it on a couple times and feeling/smelling around the fuel rail before starting it and it's a good thing I did.
An injector o-ring on cylinder 8 is leaking pretty bad. I did notice that 6 and 8 are about 1/32" higher than the rest so I'm going to have to put a spacer on top of the rails mounting tab to see if pushing it down as far as the others will make it stop leaking.
Anyway, got a couple more pictures.
Old Jun 13, 2010 | 10:49 PM
  #73
Gary-L's Avatar
Gary-L
Veteran: Navy
How come this setup requires a modification for the IAT? Why isn't everything already set up for it?
Old Jun 14, 2010 | 01:41 AM
  #74
UnregisteredUser's Avatar
UnregisteredUser
It's because the Edelbrock Performer RPM is intended for carb/TBI applications, and the Hughes part is just the Performer RPM with some additional bosses that are drilled to accept fuel injectors.
Personally I think it's a bit mickey mouse to sell the manifold without a port for the IAT sensor. But I'm weird about things like that, and if/when I get around to buying the Hughes I'm going to get the IAT into the manifold one way or another. The EGR port location looks like a pretty promising location if it'll go there without an interference problem.
Old Jun 14, 2010 | 08:41 AM
  #75
Gary-L's Avatar
Gary-L
Veteran: Navy
Well then, that makes two of us who are "weird like that" so it's nice to have company. If you get there before I do, please post an update. Like you, I abhor Mickey Mouse setups.
Old Jun 14, 2010 | 09:33 AM
  #76
PurplDodge's Avatar
PurplDodge
If I ever go into the business of making (errr...Selling) plenum pans for these trucks, i'd be calling them the "Stupid Plenum". And I wouldnt be using those ****ty FEL-Pro gaskets.
And I love my new sig quote.
Old Jun 14, 2010 | 09:38 AM
  #77
Whaack's Avatar
Whaack
Those are some great pictures and sweet intake!
Old Jun 14, 2010 | 10:01 AM
  #78
Gary-L's Avatar
Gary-L
Veteran: Navy
At the rate you wrote up a DIY, we know that you'll never go into the business of selling plenum pans.
Old Jun 14, 2010 | 10:46 AM
  #79
Sheriff420's Avatar
Sheriff420
I've seen a few different places that say it is better to have the IAT in the tube on the air box instead of inside the intake. Hughes also says that it is better to have it in there.
Old Jun 14, 2010 | 04:15 PM
  #80
Sheriff420's Avatar
Sheriff420
I just adjusted the fuel rail a little bit and got the #6 and #8 injectors pushed down to the same level as the rest and made sure they weren't being pushed to the side at all by the mounting bracket on the rail.
Well, it still leaks at the top o-ring on #8. So I'm going to pull them off and exchange them at advance. I figure I probably rolled the leaking o-ring or something. I'll find out when I pull it off.
Man it's hard to get motivated when it's in the 90s out there.
